I just got a new computer with xp home. On my old computer 98se these worked fine, but on the new one it isn't. When I go to backup on shrink it says file will be to large to burn. I looked at the size and it wasn't so I backed it up. When I go to burn on DVD-R Nero says the DVD-R is only 4.4 gb not 4.7. I put the same DVD-R in DVD decrypter and it says 4.7 gb. Anyway it won't let me burn it, it says it is too large. I'm not sure if my problem is with shrink, Nero, both, the computer, or if there is a way to adjust the nero to show the DVD-R as 4.7 gb. Any ideas where I should start.
Also I did have 2 backups ripped on a portable hard drive that I succesfully burned on the Nero on the new computer.
Its more a question of bit and bytes 4.4g 4.7gb nero has always reported file in the wrong way eg 1000 per gb not 1024 just keep your file sizes within limits and youll be ok. keep on trucking.
The electronic components of the power part adopted a lot of Rubycons.
DVD Shrink requires Nero
By jyeh74 in forum Newbie / General discussionsReplies: 42Last Post: 7th Oct 2013, 18:17 -
Nero will burn 4X, DVD Shrink-Nero only 2.5X
By happydog500 in forum DVD RippingReplies: 16Last Post: 4th Jan 2010, 19:49 -
DVD Shrink and Nero together
By moe_b_disc in forum Newbie / General discussionsReplies: 11Last Post: 1st Mar 2008, 14:23 -
Nero Recode vs DVD Shrink
By PhoneMatt in forum DVD RippingReplies: 2Last Post: 8th Feb 2008, 13:04 -
nero 8 & dvd shrink
By jerbevpicasso in forum Newbie / General discussionsReplies: 17Last Post: 24th Oct 2007, 21:36
