I heard theres a way to set the bitrate or something to DVD-Rom instead of DVD-R,making discs more compatable with players.
Do you need to mess with the firmware to do this? Or is there some program to use? I use Nero btw.
IIRC its a setting in nero.
There`s a bit setting program you can d/l at liteon that lets you set dvd+r to dvd-rom.
Under the ISO or the LABEL tab in Nero in the Write DVD dialog box before you burn.
I don't see it.Is it only available in Nero 6? Because i have 5.5.Originally Posted by smearbrick1
Star Warrior- Pm me your E-mail and I'll send you the Bitsetting tool. You will need one of the 2 latest firmware updates. It will work with any DVD burning software. It doesn't work on DVD-R discs, only DVD+R discs.
It works on hte 411 but not sure on the 451.
Here is the url:
http://www.liteonit.com/ODD/zip/BookType.zip
Tom
CD-ROM vs. DVD-ROM
By Judson in forum MacReplies: 10Last Post: 6th Apr 2012, 09:33 -
DVD Decrypter: File Mode total size double that of ISO read mode
By dare2be in forum DVD RippingReplies: 7Last Post: 13th Feb 2011, 13:21 -
Gateway AR-230 flashed to LVW-5001 , DDW-451s to LDW-451s, SUCCESS!
By FiremanPete in forum DVD & Blu-ray RecordersReplies: 1Last Post: 28th Jun 2008, 22:15 -
Advantages of ripping in File mode over ISO mode...
By hiimbored in forum DVD RippingReplies: 9Last Post: 5th Jun 2008, 16:27 -
Liteon 5001 and HQ mode problems
By oldfart13 in forum DVD & Blu-ray RecordersReplies: 12Last Post: 1st Oct 2007, 00:49
