hey there first off thanx for any help in advance.i am fairly apt with picking up hardware/software sollutions and vary rarely come across something that i cant find an answer for myself.however this one im unsure of so first off thanx for any help in advance
heres the prob i baught my nec 8x writer the other week, i also have a philips 8x dvd/cdrw drv. i have aprox 4 dvds that i am using inc hulk,legaly blonde,28dayslater e.t.c The problem is i have encountered a problem once or twice in dvddecrypt that has prevented me from ripping but have managed to work around that with dvdshrink or smartripper. The main proba at the moment is once ripped to hdd shrinking the file always fails with either overlaped 1/0 or missing something. This problem occurs on both dvdshrink and dvd2one and on both win98 and winxp. i just cant seem to get a descent shrink. The process ends at variouse stages each time slightly higher or lower. i am doing dao btw but have similar probs with just ripping the movie.
MY SPECS BE THEM SOMEWHAT MEAGER ARE.
1.4GHZ amd
266fsb mobo
128mb gf ti card
256ddr ram
120gb hdd
FACTS
now ive ruled out the OS as ive tried both 98se and xp but am willing to inst 2000.
My main concern is that my throughput on the system is to slow but surely the shrink soft would compensate for that? and is 256ddr enough its prob 2100 btw.
i also have not set any of my dvd roms to a region as i am unsure if once set e.g region2 they will still be able to play other regions? Though as i am able to rip to my hdd i ruled this out to. The dvdplayer doesnt come into the shrinking stage right?
IVE CHECKED ALL THE POSTING BUT NOT FOUND a problem LIKE THIS
could this prob be my aspi drivers?
any suggestion are most welcome i really need the help. Thanx
Results 1 to 20 of 20
im new so shoot me
also my other theory is that by not setting the region on the dvd drives the data is somehow getting corupted when ripped. is this a viable option?
i have been able to burn die another day be it onto a rubbish bulpaq dvd (now using ritek only) and this resulted in blotchy/freezing near the end of the movie which i put down to the media getting over heated.
ONCE AGAIN I REALLY APPRECIATE ANY INPUT/HELP THANKYOUim new so shoot me -
Why haven't you set your drive to a specific region yet?Originally Posted by a user with lots of i's and a 'o' in middle of his username
Have you looked at region-freeing it?
You have five choices to select the region you want; my advice would be to set it to the region you're in (UK, US, what?) and then rip again.
Have you tried playing the ripped files from your HDD with PowerDVD?
This will determine whether it's a ripping problem or not.
Okay...Originally Posted by a user with lots of i's and a 'o' in middle of his username
Good luck, hope you fix it
Will Haytgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
i have not set them to a region (uk) yet. as i tend to get alot of usa dvds and as i am aware the dvd rom can be region/changed only a certain amount of times until it is locked for good. i will of course use a region free firmware for my dvd rom but am a bit hessitent to use it for my duel nec 8x drive. as if i lock it i dont know what kind of situation i would be left with reading/ripping. Any advice on that id appreciate too.
i have sucessfully ripped them and they all play in powerdvd i just cant seem to shrink the things
i have sent the original vobs to a friend whos got a bit more experiance with this and hes going to see if he can shrink them. Ive got a feeling theyre gonna work fine for him and as i have exactly the same software as him im oagling towards the hardware/drivers. I leave the settings in dvd2one and dvdshrink as standard and have tried both 32bit and 64bit settings aswell as allow for i/o overlap. (scratches head) any ideas ???????????? Thanx for your reply m8
thanx for the reply
i have read reviews on most of the dvd(compression software) i havent checked that anydvd so ill look into that THANX! Ive researched clone dvd and found that dvd2one and dvdshrink give better quality with less foreign objects. Im basically trying to get the best output that i can (without using pinnacle) cause im not that patient lol. im not against using clone dvd though and if i cant get past these issues ill hapilly use it. But id really like to use dvdshrink if at all possible. Even if it means building a new system
. once again thanx for your input
i have just tried clonedvd on xp and to no avail. bad 1/0 was reported. So once again this brings me back to the hardware issue. Im going to throw caution to the wind and being an avid gamer/wolf/cs i am ordering a new mobo,cpu and ram. HOPEFULLY WITH THIS FASTER SYSTEM i will not recieve these issues. ID LIKE TO THANK YOU ALL FOR YOUR INPUT
I'm sorry if this sounds a bit vague but I seem to recall that Win XP has a problem with burning. I seem to remember something about having to turn off the OS's own burning facilities as it interferes with any other burning software. Unfortunately I don't have any details as I refuse to use XP after a short evaluation for my company, but I should think a little searching on this site will throw up something relevant.
IMHO Win 2000 Pro is far better and presents less problems, but that is my own (professional) opinion and not necessarily shared by others.Artificial intelligence is no match for natural stupidity. -
Strange, because I heard the opposite, and probably the reason Win2000 was so short-lived.Originally Posted by Duchess
I have had no burning issues with WinXP, which I found to be the most stable of all OS I ever tried/used, in fact your message was the first I've heard of it.
Sorry if this sounds vague, it's my professional opinion
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by iiiiii0iiiiii
I would say the first otion would be to region code your drive.
Worst case and assuming you do use up all five options to change the coding; they're only £20 ($36) a time now.
Still, wish I could upgrade mine machine right now
Good luck
<chuckle> Where can you get Win XP Server? Most companies I know of are using Win2K Server and Win2KPro on the PC's and wouldn't touch XP with the proverbial barge pole.Strange, because I heard the opposite, and probably the reason Win2000 was so short-lived.
I thought it was ME that was the short lived OS, but then I've probably got everything all wrong. <g>
Why can't you?Still, wish I could upgrade mine machine right nowArtificial intelligence is no match for natural stupidity. -
Sorry, did I say/infer I was in IT?Originally Posted by Duchess
I'm a Quantity Surveyor
Originally Posted by Will HayDaniel two next week and a baby girl due March 24thOriginally Posted by Duchess
Nice tryOriginally Posted by Duchess
By the way, am I mistaken, or is Athlon spelt "a-t-h-l-o-n" ?
Congratulations, and what are you going to call her? I can understand why you can't afford a new pooter tho'.Daniel two next week and a baby girl due March 24th
Now where did that come from?By the way, am I mistaken, or is Athlon spelt "a-t-h-l-o-n" ?
BTW the reference to XP problems that I mentioned were the result of another thread I read on this site. Someone was having similar problems to the starter of this thread, and others responded with the comments regarding the turning off of XP's own burning monopoly.Artificial intelligence is no match for natural stupidity. -
We were leaning towards Eva then I saw a documentary on the History channel; I've forgotten about Hitler's girlfriend, it put me right offOriginally Posted by Duchess
By the way, am I mistaken, or is Athlon spelt "a-t-h-l-o-n" ?You know, right?Originally Posted by Duchess
Sorry, couldn't resist, we all make mistakes, even the professionals
lol
i too first put it down to xp and i do know alot of computer advanced users that swear by 2000 just as i swore not to use xp but hey a duel boots not to much hastle and its about the only way to prepare for longhorn well without installing that beta lump(milestone).
Anyways ive spent a while oagling all the cpus and mobos and 1minute 30seconds ago i purchased my new amd 3200+ xp 400fsb. This is probably when u lot are gonna frown at me for not choosing the obvious leader for encoding (intel) but first and foremost im a gamer
. ive got some sweet ram on its way too 1gb along with a nice lanparty mobo they should be here by 2morrow and with a bit of hair pulling out and plenty of beer im sure ill have it up and running by this time 2morrow.
so ill make sure to test shrinking as soon as ive played 5 mins on wolf lol
i have locked the drive now but will wait for the new system before i test her out.
CONGRATS WILL ON THE LITTLE ONE who knows mabye she will turn out to be the next billie gates then dadys gonna have a new sys
Thanx once again
I don't blame you for using Athlon's, up until my last machine I did too but I wanted a machine that would fit in with the Hi-Fi system. As a result I got one of those mini cases and the only mobo's that were available for it were Pentium based so I had no choice. Still I now have a 3.2GHz machine with 1Gb RAM and 250Mb of HDD.
Good luck with the building.Artificial intelligence is no match for natural stupidity. -
I've never had Intel since my P75!
You might want to consider investing in a bigger HDDOriginally Posted by Duchess
Whoops !!!!!!! Silly mistake, I don't think that would even hold the operating system, never mind all the rest of the stuff. <g> Obviously I should have said 250Gb
Problem with DVDShrink
By abba1961 in forum DVD RippingReplies: 3Last Post: 22nd Mar 2010, 02:52 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 20:33 -
Which is better - shrinking with DVDShrink or......
By robertazimmerman in forum DVD RippingReplies: 21Last Post: 4th Feb 2008, 14:12 -
Problem with dvdshrink
By malleus in forum Newbie / General discussionsReplies: 4Last Post: 10th Oct 2007, 22:03 -
Problem shrinking Freedom Writers
By woodcutter3 in forum DVD RippingReplies: 1Last Post: 4th Jun 2007, 04:00
