Hello,
I used TMPGenc to convert .avi to DVD format. After TMPGenc finished encodind it has created a .M2V extention file. Question is how do make a DVD-Video (to burn as DVD-R) from .M2V file. I tried using Nero but it did not like the file extentions.
Thanks in advances.
Author it together with audio (of some kind - LPCM WAV, AC3, MP2) (as m2v is mpeg 2 video) using an authoring application as IfoEdit, TMPGEnc DVD Author, DVD-Lab...
/Mats -
My reply is still valid - Take your m2v and your audio file and author.
/Mats -
I must say that applications that just look at the extension to determine their type is sloppy programmed. The least you could ask for is for the app to at least try to open it to take a peek at what it really is. (freeware excused...)
/Mats -
I had a similar problem with TMPGEnc plus when I was first learning to use it. In TMPGEnc plus you select the output file type on the main screen where you choose if you want video and audio in the same file.The plus software will create a .mpg file when you include boath audio and video or seperate files like .m2v and .wav. I think that standard TMPBEnc is the same in this reguard.
NOTE: The selections allowed are based on what you have requested in other parts of the program. If I select PCM (.wav) audio output, it will not let me select a single .mpg file. (The request would not make sense).
Problem converting jpegs to m2v
By PirateAhoy in forum Authoring (DVD)Replies: 0Last Post: 22nd Apr 2012, 14:57 -
problem converting swf created by jing capture
By surfmonkee in forum Video ConversionReplies: 2Last Post: 22nd Feb 2010, 04:33 -
Mysterious green screens that appear after converting to .m2v...
By dum_hobo in forum Video ConversionReplies: 0Last Post: 14th Jan 2009, 21:19 -
Converting Video for a Blackberry using TMPGEnc
By Vachoen in forum Video ConversionReplies: 3Last Post: 9th May 2008, 15:06 -
Demux DVD Video to separate M2V and AC3 files
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 3Last Post: 6th Oct 2007, 20:03
