Results 1 to 15 of 15
Hi nib,
Check out:
https://www.videohelp.com/guides.php?guideid=10#10
(Can't remember if it contains your actual problem - haven't read it for a while).
Please remember to rate the guide...
Good luck.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
If you're not living on the edge, you're taking up too much room. -
Thank you in same but I don't see solve for this specific problem.
It very strange he appear whith any video (.avi) filenib :)) -
If it appears with any video, I would guess that it's a conflict with TMPGEnc and other software, or the installation of TMPGEnc wasn't totally successful.
Try closing any software that you don't need (i.e. disconnect from the net and close firewall, virus scanning software etc. as well as any other programs you don't need) and then try it. Check Task Manager to make sure that the programs are properly shut down.
Or, uninstall TMPGEnc, re-boot the machine, and re-install.
Beyond that, I don't know (as the above is what I would do...).
Carpe diem.
Check your settings and increase Direct Show priority. In my version it's in global settings, I think it's called environmental settings in current versions(?) Go to VFAPI plugins and right click Direct Show, then click increase priority until it's at the top. Then use a template without changing anything there. Hope that does it for you.
Just checked the guide Daamon pointed you to. Yeah, your solution is almost certainly there. Good luck.Pull! Bang! Darn! -
Hi nib,
The link I gave takes you to a page with details of the guide, not the guide itself. When there you need to click on the URL (https://www.videohelp.com/tmpgenc.htm#problems) under where it says the word "Link".
I've hade a look, and the second one (starts "If TMPGEnc freezes or crashes...", and contains "Write error occured at address...") might be the one for you.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hello again
The problem is the same after I put the Direst Show in first position and priority higher
If you now more thing tell me, PLEASE
Thank younib :)) -
Have you tried either of the above?Originally Posted by daamonThere is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Hi
Yes I do all that things, remove, close every programmes I don't use of much time.
I don't now who make more, maybe reinstall windows
nib :)) -
Sorry nib, that's all I can think of...
I've not seen that problem myself. I had a search through the forums, and found this link:
https://www.videohelp.com/forum/viewtopic.php?t=134090&highlight=
Particularly, see the post by Nikolai on 04 Jan, 2003 09:33...
...that may be of use.
Good luck. Sorry I couldn't help more.There is some corner of a foreign field that is forever England: Telstra Stadium, Sydney, 22/11/2003.
Carpe diem.
Have you tried running an AVI through VirtualDub first to mask bad frames and decompress the audio?
Pull! Bang! Darn! -
Thank you daamon for everthing
If I was make run an AVI through VirtualDub first to mask bad frames the answer is Yes
After this I don't now who make morenib :)) -
Hello
I solve the problem.
And the problem is :
The new ram memory in pc, yes just this, can you beleave it
Thank you everbody and have a nice daynib :)) -
Good news -
Carpe diem.
Thanks for the follow-up. Too many fail to extend that courtesy and everyone's left none the wiser. Congratulations.
Pull! Bang! Darn!
Read error with TMPGEnc
By MasterScreech in forum Authoring (VCD/SVCD)Replies: 2Last Post: 24th Jun 2010, 19:08 -
Video has a ripple effect whith any movement?
By David9799 in forum Software PlayingReplies: 4Last Post: 13th Aug 2009, 18:35 -
TMPGEnc Read Error
By koberulz in forum Video ConversionReplies: 0Last Post: 6th Nov 2008, 21:44 -
exportation in m2v whith Adobe premiere elements 4
By 16/9 in forum EditingReplies: 0Last Post: 7th Dec 2007, 14:32 -
TMPGEnc Plus Error!
By redtrigger in forum Video ConversionReplies: 15Last Post: 9th Jul 2007, 11:05
