Okay I tried my first burn using dvd shrink 2.3, because the instructions on this forum were easier to follow. I followed everything exactly like it said used copy2dvd to burn and got nothing. It seemed to be burning fine then at the end it finished like I thought it would and spat the dvd out.
Well I then tried it on every dvd player in my house and nothing, not even on the computer it was made on. It seems like there is nothing on it but it isn't read as a blank anymore, on my Sony home dvd player it said the disc was dirty
Anyway I am thinking of using the newest shrink, and the Nero I just got see if that helps. The thing is I already have RecordNow which came on the PC and I am wondering if it will cause any conflicts, but before I venture off on my second try any suggestions on what to different would really help
Just in case I am using a Ricoh DVD+RW MP55240A
on WinXP with Memorex DVD+R 4x
and was trying to backup Final Desination 2
Results 1 to 10 of 10
Try this method
1. Dvd Decrypter
2. Dvd2One
3. CopytoDvd
Here is a guide
http://www.lordsmurf.com/dvdcopy/dvd2one/dvd2one.htmWhat We Do In Life, Echoes In Eternity.... -
Hey I just made a bkup of Final Destination2. Its a flipper disk. One side pan and scan and the other side is widescreen with AC3 and DTS sound tracks and all the extra's. The prob I had was DVD Shrink wouldnt shrink (custom ratios) the WS enuf with all the extras to fit so I DVD Decrypte it to HD then used CloneDVD to shrink and burn it to fit. Picture looks OK. The PS copy doesnt need to be shrunk.
I used
DVD Decrypter
CloneDVD
and bingo, bkup'd -
if its a dual stded dvd, it needs to be ripped with dvddecrypter, or smart ripper in file mode, before using dvdshrink
Alright I tried Denver Dawgs method and I got the exact same result has before, the dvd seems to be blank and when I put in my Sony stand alone player it said the disc was dirty, at least this time there was a visible burn circle on the DVD
What the hell could be wrong I mean my PC is brand new, or could it be the burning software because thats twice that I use CopytoDVD and get the same result, any suggestions? I really don't want another expensive ass coaster -
Have you checked to see if your dvd player can play R+-? Also, the brand can cause this. Its a trail and error thing with burning. So don't go buy a huge spindle of dvds until you find ones that are compatible with your specific dvd player...Good luck, keep me posted.
My player has a sticker with both DVD-rw/-r and DVD+rw/+r, but even if it was my player they should at least play on my PC which they don't and the Richo drive I am using says DVD+rw and that is the reason I purchased those memorex DVD+r...so i am stuck,
I knew I should of bought a 3-pack of DVD-rw's for testing -
You live. You learn......
Okay 4 coasters and not a single backup yet, this time I tried using Shrink and the instant copy program, when I try it on my PC it says disk not formatted and won't play in my stand alone either.
Something I've noticed in all the coasters I've made is that it says there is 2KB on the DVD but the entire DVD is taken up. Any suggestions? I am just about ready to give up on backing up movies -
Finally! On my fifth try I finally backed up final destination 2. Here was what I did, used DVD Decrypter, shrunk it with DVD shrink 3.1, then finally used ImgTool Classic to create an image or iso of the AUDIO_TS and VIDEO_TS folders. Then I burned it with decrypter and done it worked! plays everywhere.
Video quality is great and managed to keep both the the DD track and the DTS track. Thx to those who tried to help me
Incorrect Timing on DVD burn: H.264 mp4->ffmpegx->Toast or Burn
By DirectorSG in forum MacReplies: 2Last Post: 29th Jan 2012, 12:42 -
Trouble Editing/Trouble Base Media?
By SlickPen in forum EditingReplies: 0Last Post: 20th Mar 2011, 19:53 -
DVDs burn fine, but Audio CDs only burn 1st half of songs right...
By Xenogear900 in forum Authoring (VCD/SVCD)Replies: 7Last Post: 28th Jan 2010, 04:26 -
Advice required when trying to burn with img burn
By IPBR21054 in forum SVCD2DVD & VOB2MPGReplies: 4Last Post: 1st Aug 2009, 16:29 -
Burn Software with Menu & burn xvid avi
By CynthiaBlue in forum Newbie / General discussionsReplies: 3Last Post: 4th Jul 2007, 20:46
