Hi Baldrick and every one else![]()
I`v been using your `How to convert WAV/MPA/MP3 audio to AC3(DD) using Besweet` guide and I like it very mach, its helpful understandable and easy to follow so good one there.
Now I have a question about wav2ac3 process and I thought that you maybe know the answer for what's bugging me for days now
I'm using your guide for making DVD-Video with AC3 audio stream, and it works fine with all AC3 files that has 5.1-6ch but I have a problem with the stereo AC3 ones…![]()
First i`m making an AC3 file out of a large stereo WAV file, then I muliplex it with MPG file (using bbmpeg) and last check the file for compatibility on monitor and burn it with nero6 .
The problem is that I can't hear the sound when I'm playing disc on my DVD player.. although it played very nicly on comuter screen
I can only hear the audio when its 5-6ch AC file..![]()
How can u explain that? I used the same way to create all files..
I`v tried this thing with about four movies and all ac3 stereo won't work…
Tried playing movie in other DVD player to check if it's my players fault but none of them worked on other players (but the 6ch did…)
Now I've also noted that " Besweet with ac3enc does NOT create 100 % compliant ac3 audio files. It doesn't work on some Pioneer players for example."
So its not the case here since I have a different brand and the other files I've created works fine.
Is it my mistake? Or is there another way for making ac3 stereo file ?
should i use different settings in Besweet ?
Please help me out here.
thanks a lot.![]()
By Baldrick in forum User guidesReplies: 89Last Post: 11th Aug 2012, 16:14 -
BeSweet for 4.0/quad AC3?
By RogerTango in forum Video ConversionReplies: 1Last Post: 17th Nov 2011, 03:16 -
Problem with BeSweet/BeLight. Trying to batch convert Ogg Vorbis to ac3.
By rayden54 in forum AudioReplies: 9Last Post: 30th Dec 2008, 18:37 -
Convert stereo ac3 with bad channel to mono ac3
By chipsndukes in forum AudioReplies: 7Last Post: 5th Nov 2008, 11:23
