Hey guys, i was thinking of picking up a DVD burner and wanted to see if it was worth it.
my main goal will be to "back up my DVD movies"wink, wink
can anyone tell me some general pros and cons that have come up recently? ie. some DVD are to big for DVDrs??
thanx for your help guys
aPeG
I have the vob instant cd i ruined my first dvd, it copied but it will not play. I then saw an option under profiles to choose the disk type (dvd-rom), not sure if that effected things, the help said it generally doesn't matter
I was able to use smartripper and rip the video to disk fine from the copy that wouldn't play on pc-dvd or stand-alone. Leads me to believe it might be a macrovision problem.
When i get my new disks i ordered, i am going to try backup it up again using smartripper, then record the files to disk, has anyone used prassi dvd-rep, i might try that.
I do know that some single sided disks are over 4.7 gigs, which would have to be split to multiple disks.
has anybody, found a direct-copy solution that works for the pioneer-a03?
or successful ripped then burned the disk?
I would appreciate the help, disk's are quite expensive right now, nearly 1/3 to 1/2 the price of most movies. -
THANX BUT NO THANX
please put your own questions in a new topic
still looking for some help
thanx guys
DVDFab Blu-ray Copy vs. DVD Copy
By coody in forum Blu-ray RippingReplies: 1Last Post: 11th Oct 2010, 13:33 -
Copy of a Copy of a Protected VHS Tape to DVD
By solarblast in forum DVD & Blu-ray RecordersReplies: 12Last Post: 18th Dec 2008, 08:36 -
Is copy Sony PSP game same as copy DVD disc?
By coody in forum ComputerReplies: 10Last Post: 15th Dec 2008, 08:26 -
How can I copy a copy-protected DVD and have only ONE VOB file
By Aafour in forum DVD RippingReplies: 3Last Post: 6th Oct 2008, 01:31 -
Unable to copy copy-protected data DVD
By J_Kirk in forum ComputerReplies: 9Last Post: 22nd Jan 2008, 12:23
wink, wink
