Hello.
I just successfully installed my brand new TDK 880 8x/8x burner into my computer, and I have downloaded the newest versions of DVD Shrink and DVD Decrypter. I think that I know how to rip the files to my HDD with Decrypter, and I think I know how to comprtess with DVD shrink...
My question: Can I use Roxio 6 to burn the files that DVD Shrink creates??? Everybody around here says how much Roxio sucks, but it's the only program that came with my Drive.
Please Help! I'm clearing files off my HDD in anticipation of my first burn, if I cannot burn with Roxio 6...then what should I get? Is there any freeware that can do it?
THANKS A MILLION in advance.
Results 1 to 14 of 14
Niners aren't linear, We're everywhere!
It was a bright cold day in April, and the clocks were striking thirteen. -
I use only DVD Shrink. Decrypter is not required as shrink with rip the dvd by itself. If you switch to Nero, Shrink with also burn the disk for you all in a single operation. I Rip the DVD from a DVD rom drive and burn with my NEC 4x External USB 2 drive. I pop the blank in it as I an ripping from the rom drive. As soon as it is done ripping the parts of DVD you wan it preceeds to burn it. I do not use Roxio. Roxio has some issues with other programs.
No DVD can withstand the power of DVDShrink along with AnyDVD! -
Yeah, DVDDecrypter can burn for you. If you have to run the movie thru DVDShrink to reauthor/delete extras/reduce file size, you'd need to make an ISO image first before burning with DVDDecrypter. No problemo, do it with ImgTool Classic. Both are freeware. If the movie isn't too big, you can just rip/burn in ISO mode with Decrypter.
I've normally used Instant Copy heretofore, but it has an annoying habit of re-encoding sometimes. So I more and more often do the extra step of making an ISO and burning that. And if the ImgTool/DVDDecrypter method doesn't work, nothing will. Something else is wrong.
Wouldn't bother with Roxio personally, it's rep isn't good. BTW, you'll find that an extra harddrive would be useful.Good luck.
Pull! Bang! Darn! -
go here http://expage.com/howtocopydvds4free it is great it shows how to copy dvds w/ dvd shrink
Go to http://www.expage.com/howtocopydvds4free it Rocks! -
The method I use is pretty easy, everthing is freeware. Use Autoshrink ISO, DVDshrink, and DVDdecrypter to burn. Works automatically after you have made your choices in DVDshrink. It is very handy if you have both a DVD rom and a seperate DVD burner.
Originally Posted by shelbyGT
I just used DVD Shrink to Rip to my Hard Drive. Then, used Roxio's "Disc Creator Classic" or whatever the hell it's called and burned the audio and video_ts folders to a blank DVD-R.
THIS IS SO F**KING COOL.
Now I'll have to try a DVD that needs to be compressed?
Does anybody see problem using this method? The DVD-R played perfectly on both of the players that I've tried. Do I reduce broad compatability by using Roxio??
Thanks.Niners aren't linear, We're everywhere!
Hell Yeah.
Just burned a backup of a movie onto a DVD+R at 6X and it WORKED on both of my DVD player as well.
Snaps.
This is frickin great!Niners aren't linear, We're everywhere!
strike, you are using the same method that I use and I have yet to get a coaster after a couple months of steady burning.
the problem with Roxio is that it doesn't burn the correct UDF format, unless that fixed last I used it. That's usually not a problem with most newer DVD players but older players don't often support any UDF format but 1.02 and I Roxio burns it in 1.05/1.5
Glad you got it working, but I was initially using the same method as you (DVD Decrypter, DVD Shrink, Roxio 6 to burn) and I burnt two coasters. Got rid of Roxio and started using CopyToDVD to burn and haven't had a problem since. I ripped, shrunk and burnt four DVD's this past weekend with no problems using the new methods.
Several people here say use Shrink only, but Shrink had problems decrypting two of my DVD's, but Decrypter had no problem with them. So for now, I'm going to leave that extra step in there just to be safe. I also re-installed Nero 5.5 and will try that on my next burn. I guess there are so many factors involved that not all solutions will work for everyone. You just have to find one that works for you, and it appears that you have. Good luck! -
Originally Posted by Poppa_Meth
Try
1. Dvd Decrypter
2. Dvd2One
3. CopytodvdWhat We Do In Life, Echoes In Eternity....
Can Roxio USB capture be used without Roxio's software?
By miamicanes in forum Capturing and VCRReplies: 4Last Post: 18th Oct 2012, 16:30 -
Roxio dvd burning question
By celchlepp in forum Newbie / General discussionsReplies: 1Last Post: 21st Feb 2010, 20:32 -
SVCD2DVD when going to DVDShrink & DVDShrink Re-Author Problems in Vist
By pcandmac2006 in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 23rd Jan 2009, 19:33 -
DVDShrink Updated? to work with Imgburn
By Bronx in forum Newbie / General discussionsReplies: 5Last Post: 13th Aug 2007, 09:12 -
DVD Decrypter wont work with my external drives?
By dazza555 in forum DVD RippingReplies: 4Last Post: 23rd Jun 2007, 19:04
