Hi, guys:
In a TMPGEnc tutorial at
http://www.digitalFAQ.com/guides/video/convert-tmpg.htm
as well as in some guides, there are instructions on setting priorities for various codecs
(Environmental Settings-> "VFAPI Plug-In" tab)
A list of various decoders is given with priority settings. I reproduce it below.
Direct Show multimedia File Reader,Ligos MPEG-2 Decoder,CRI Sofdec MPEG Decoder,AVI2(OpenDML) File Reader,Cyberlink MPEG-2 Decoder,Microsoft MPEG-1 Decoder,Wave File Reader,TMPGEnc Project File Reader,The file can not be loaded,BMP/PPM/TGA/JPG,AVI VFW Compatibility Reader
My question is: does TMPGEnc depend on third-party codecs in order to process AVI files?
A guide at dvdrhelp.com/tmpgenc.htm
says the following with regards to priority settings in VFAPI plug-in :
First install a DV Codec and be sure that you can play DV AVI with Media Player.
Am I correct in assuming that people who use AVI files from different sources are more likely to need more various decoders? But if I am using my own AVIs, I can manage with one or two decoders, as long as those AVIs can be played in my computer?
If someone has gone into trouble of installing Ligos decoder in his computer, is it likely to be for the purpose of being able to open a wider range of AVI files when using TMPGEnc? I would imagine Ligos decoder comes with Ligos LSX MPEG-2 Encoder, but that is a payware, more expensive that TMPGEnc itself.
Thx wh
Yes.Originally Posted by walter4h
AVI is a package containing compressed streams. The AVI file readers listed in TMPGEnc VFAPI tab just let Tsunami deal with the AVI format. When an AVI is played, its separate streams are decoded (Audio / Video).
TMPGEnc can deal with the container "AVI", but has to rely on installed VFW codecs, or DirectShow decoders for the compressed streams inside (Audio / Video / etc).
Logos MPEG-2 decoder only decodes MPEG-2, not AVI. Cyberlink MPEG-2 decoder only decodes MPEG-2, not AVI.
Other "Containters" you might come across:
Matroska
Ogg
*Usually any compressed streams you can put into AVI package, you can put into Matroska or Ogg.
TMPGenc Xpress 4 and Mpeg Video Wizard DVD VFapi plugin
By stanB in forum Video ConversionReplies: 0Last Post: 28th Jan 2011, 15:46 -
Tmpgenc 4 plug-in settings cant be changed?
By mrjust in forum Newbie / General discussionsReplies: 0Last Post: 27th Mar 2010, 23:50 -
TMPGEnc Settings?
By chronic777 in forum Video ConversionReplies: 3Last Post: 27th Jul 2009, 10:14 -
TMPGEnc DVD settings
By Bully9 in forum Authoring (DVD)Replies: 3Last Post: 12th Mar 2008, 09:22 -
Doubt about TMPGEnc Plus' settings
By alvabass in forum Video ConversionReplies: 1Last Post: 13th Jun 2007, 12:52
