O.k...........
I have burned of a film to DVD. i Have an Pioneer 05, i used TMPGEnc to join the two files as they were Mpeg and V dub will not allow you to do this.
i then frame checked the audio and saved the Wav file.
Went back to TMPGEnc and created a M2V file.
Then using Ifo to repair .IFO's or sectors, which i got told to do?
Demuxed the files.
Then onto DVDclone to burn the dvd.
When i played the video_ts file before burning through POWERDVD the audio was fine but the video would only play on x2 speed.
so after burning i played the dvd again but in WMP. video fine but no audio, tried powerdvd again still the same.
Well i took the dvd to my ps2 which is chipped..... and the dvd played but the audio was out of sync and popping in and out........
Does the procedure i have used seem right and what can i do to make this more precise?
Also what is the deal on the audio with this dvd.............?
many thanks..........
D
Results 1 to 1 of 1
Burned blu ray on standalone player, I have audio but no video
By BAMFstang in forum Authoring (Blu-ray)Replies: 2Last Post: 19th May 2010, 14:28 -
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 03:57 -
no audio in divx files on standalone player
By kaston in forum Authoring (DVD)Replies: 14Last Post: 27th Oct 2009, 22:26 -
[SOLVED]Audio won't play for an AVI file in my standalone DivX/XviD player!
By =CrAzYG33K= in forum AudioReplies: 4Last Post: 13th Oct 2008, 09:32 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 13:56
