My mates PC has suffered a nasty attack from what he tells me is the Chernobyl virus. His machine now fails to complete a chkdsk upon startup and he has a stack load of corrupted files and folders that just won't delete. On top of that the Master Boot Record has been damaged.
If I offer to go round and take a look will I soon be upto my armpits in PC related sh!t ? Or shall I tell him to take it down to PCWorld ?
Buddha says that, while he may show you the way, only you can truly save yourself, proving once and for all that he's a lazy, fat bastard. -
Have you tried booting in SAFEMODE/COMMAND PROMPT and running FDISK /MBR ? That should fix a Boot Record issue.
Also -- you may want to goto Norton (Symantec) and see what the extent of damage caused by Chernobyl is and any processes to recover. -
Mmm, FDISK the MBR. That's old-school geek talk
Other option is running disk first aid by booting from the OS installation disc. I can't recall the steps for this though I think it prompts you on screen. I had to do it a few months ago after a failed attempt at dual-booting Linux.
Can I re-install older dual-boot OS and still have the dual-boot work?
By jeanpave in forum ComputerReplies: 8Last Post: 3rd Dec 2011, 01:06 -
Suggestion to Web Master
By rcubed in forum FeedbackReplies: 0Last Post: 3rd Aug 2011, 16:29 -
master dvd
By butterflies in forum Authoring (DVD)Replies: 6Last Post: 3rd Feb 2010, 01:51 -
Who here has used or is using a Channel Master CM-7000?
By Frank-0-Video in forum DVB / IPTVReplies: 7Last Post: 25th Jan 2009, 14:13 -
"Master" Master Audio Volume Control?
By Soopafresh in forum ComputerReplies: 1Last Post: 19th Mar 2008, 08:57
