I can't open a *.vdr file. I get this - file unsupported or can not open or is not supported - message
I've tried this Try first to change the directshow codec reader priority settings in TMPGEnc under Option->Environmental settings->VFAPI plug-in and right click on the DirectShow Multimedia File Reader and increase the priority to 2 or to the top of the plugin-list and try reopen the video.
If that does not help be sure that you have installed DivX or XviD or MPG2 or DV Codecs, read here how to identify what codecs you need.
as suggested in the Common problems and Tips for TMPGEnc.
If I play the file in VirtualDub, Winamp, RealPlayer it's OK
Anyone??? TIA![]()
I'm trying to add subtitles with VirtualDub as frameserver and TMPGEnc as I've done many times before. I think I've got all the codec, since I can see the movie.
G2spot says all codec are installed, and if I open the *.avi file in TMPGEnc instead of the *.vdr file, I can preview the *.avi file in TMPGEnc. -
In Virtualdub did you run the auxsetup.exe and install the handler?
Just shut up and listen dumbass -
Try a simple script in avisynth
AviSource("c:\folder\myclip.avi")
If it opens in mplayer2 it will serve to tmpgenc too. Use Trumans avisynth subtitler here's a good guide.
https://www.videohelp.com/forum/userguides/99389.phpJust shut up and listen dumbass
Can not open any file in TMPGEnc 4
By Soixante in forum Video ConversionReplies: 4Last Post: 8th Sep 2010, 08:56 -
avidemux won't open a DV .avi file
By BrianK in forum Video ConversionReplies: 2Last Post: 14th Jul 2009, 10:10 -
can't open file in TMPGEnc
By windranger in forum Newbie / General discussionsReplies: 12Last Post: 18th Feb 2009, 09:25 -
TMPGenc DVD Author 3 will not open file from TMPGenc Xpress 4.0
By artyjeffrey in forum Authoring (DVD)Replies: 4Last Post: 8th Nov 2008, 13:23 -
Nero won't open .mp4 file
By ChickaJane in forum Video ConversionReplies: 8Last Post: 21st Aug 2007, 23:38
