Yesterday I decided to do a little testing to see the differences in VCD/SVCD/SeVCD and SxVCD. Problem is I cannot get the SxVCD to play after the conversion. All 4 files done exactly the same way. Using Sefy's SxVCD template, all I get is a black screen and stuttering sound. Can't figure out why it does that.
Also, is it normal for the converted file sixe to be soo much larger than the avi? A 1MB avi file converted to approx. 1.6MB on all 4 files. Doesn't sound right to me, but hell, I don't know jack yet.
So if anyone could straighten me out, I'd appreciate it![]()
If your AVI file was a DivX encoded file, it is very likely that the MPG version of it would be much bigger, considering a 1min standard VCD would take 10mb, and the SeVCD and SxVCD would give you slightly smaller file sizes, but still larger then AVI encoded with DivX.
As for SxVCD, since it uses MPEG2 and it's non-standard, it is not very playable on Media Player, you are better off using PowerDVD or WinDVD, or any other DVD Playing software.
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
Well dam Sefy. You pretty much answered all my questions there.
Really appreciate the help and templates. I'm still learning here, but you and this site are a huge help. Again, very much appreciated.
Glad I could have been of help, let me know if you got any more questions
Best Regards,
Sefy Levy,
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
File size problems when playing from USB?
By BBQchicken in forum DVD & Blu-ray PlayersReplies: 8Last Post: 16th Nov 2011, 18:26 -
dvp5992/37 - USB memory stick movie file size questions........
By tracnet in forum DVD & Blu-ray PlayersReplies: 5Last Post: 6th Jun 2011, 15:58 -
A few questions regarding quality, file size, etc...
By smackyourfupa in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 07:11 -
Question: MKV File Size vs MP4 File Size
By VideoNoobz in forum MacReplies: 6Last Post: 20th Feb 2010, 02:44
