Need to buy a new camcorder.
Both Sony and Canon are coming out with new models for their DCR-TRVxx and ZR-xx lines.
They will be available over the next month or two.
Base on the two current series, my question is which series is most mac friendly?
Which series has the best hardware longevity (won't break in a year or so)????
Thank you,
DD
Well, based off the current series..
That would be the TRV-22 (mine, for instance) I'm using mine w/ my w98
system. User friendly is only a matter of having a cooperative Firewire card.
Example of cooperative ..
* My main pc will not work w/ my TRV-22
* But, my main pc CAN work w/ my Canon ZR-10 (older circuitry)
* My 2nd pc CAN work w/ my TRV-22 :P
As far as opinions go.. based on my experience w/ a Canon and Sony, I would
have to say that Sony 's line of the TRV 's are pretty good.. thanks in part
to the Lens. That was the "key" to Sony's TRV series. There is a definate
difference in picture quality pitted up again each other.
The above was my .2 cents worth :P
-vhelp -
go to best buy and look in their rerun case.
I didn't see many sony's but a lot of Canaon's ( fwiw )God Bless -
RETURN CASE ( idiot not rerun case ) need to use spell check
God Bless -
I checked Consumer Reports prior to buying. I don't always agree with their conclusions, but I have found their collective repair records to be useful and accurate.
Sony, according to CR has BY FAR a better repair record than does Canon.
Just something to consider --- your mileage may vary! -
Go with the sony. It has poor indoor lighting performance but the cannon will be much worse. Sony has 1/4.7 ccd and cannon has 1/6 in ccd.
Sony DCR-HC24 on Windows 7
By slobadaca in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 26th Mar 2013, 10:41 -
Sony DCR-TRV340 stuck on DV IN - help!
By MasterUnholyWar in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 3rd Mar 2010, 15:25 -
sony dcr hc30 firewire help
By selinanew in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 28th Jun 2007, 13:19 -
Sony DCR-SR200 and a Mac...
By carbonem in forum MacReplies: 3Last Post: 26th Jun 2007, 10:23 -
Sony Handycam - DCR-HC20E
By nzmikey in forum Newbie / General discussionsReplies: 4Last Post: 10th May 2007, 05:17
