    Holland
    When I want to cut an .AVI file the following thing happens.
    When cutting from the beginning of the file to halfway everything works fine.
    But when I want to start from halfway to the end of the file the audio stops right in the beginning.
    So the first half is perfect but the second half has no audio????
    I don't get it
    Direct stream copy is selected for both audio and video.
    I'm running Windows XP pro here, maybe a problem?
    Or is the AVI file bad?
    I never had this problem before
    Joris
    The truth is out there........
  2. I have the same problem as Joris, but i am running win2k
    If anyone has any thoughts on why this is happpening then it will be much appreciated. The AVI file plays excellent using any player, but when being cut the second half has no audio.
    Thanks People
    Syndicate
