ive been using tmpgenc to convert my xvid tv episodes to vcd mpg, by just throwing them into the wizard, making sure to use the same frame rate, when i author them usually with either vcd gear or nero as vcd's they seem to suffer from dropped frames, ( being my best guess as to the the problem i get with play back). the only way ive been able to get around this is to author using nero vision express which takes way to long
is there any thing i can do to correct this in tmpgenc???
I believe you are not dropping frames, which usually happens only during capture. I believe you have "jerky playback" which is more common with encoding. Try using different field orders, to see if it helps.
Hello.
Fast Foward / Rewind xvid or mpg?
By fredfillis in forum Newbie / General discussionsReplies: 3Last Post: 8th Nov 2009, 04:06 -
Best Method of IVTC to use In Converting HDTV .mpg to xvid
By onesikgypo in forum DVB / IPTVReplies: 7Last Post: 30th Sep 2009, 00:13 -
High Quality MPG to XviD?
By Mdoodm1000 in forum Video ConversionReplies: 26Last Post: 8th Aug 2009, 07:31 -
mpg to avi(xvid) problem
By okman in forum Video ConversionReplies: 4Last Post: 6th Jun 2009, 05:00 -
WMV and MPG to Xvid or MPG2?
By videohalp in forum Video ConversionReplies: 2Last Post: 27th Sep 2008, 23:16
