I recently purchased a dvd writer after a couple of years of making (s)vcd's and am obviously interested in creating dvd's now. I have followed the tmpgenc procedures along with extracting audio using virtualdub. I use tmpgenc dvd author to create the dvd files using the mpg that tmpgenc spits out. Unfortunately, the Audio_TS folder is empty. I can view the video just fine but there is no sound obviously. Anything obvious that I am doing incorrectly?
The audio_ts should be empty. It is only used for the DVD-Audio format and not DVD-Video.
Do you hear any sound if you play the mpg before authoring?
Do you hear any sound on your computer after authoring? -
the AUDIO_TS folder is always empty -- the sound is in the VIDEO_TS folder muxed with the video
At first I didn't extract the audio with virtualdub. When I played the movie, the video was fine and there was audio for 3 seconds and then nothing. Now I have used virtualdub to extract the audio and will attempt again. Thanks for your help. I basically needed confirmation that Audio_TS is supposed to be empty.
Will placing a text file in the AUDIO_TS folder cause a problem for players? I havent had any playback problems on my own set top players when doing this, but what about the rest of the players out there? I know DVD-Video doesn't use this folder for anything, but was just wondering if altering the file structure by placing files in a folder that's supposed to be empty for DVD-Video causes problems for any other players out there.
Originally Posted by sacajaweeda"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I put files all the time in the audio_ts folder when I am burning a DVD-RW because my player won't read DVD-RW unless there is at least 4 GB of data on it.
I am happy to report I never any problem on playing any of these disks on any of the DVD players I had access to.
AUDIO_TS folder
By siluet in forum Newbie / General discussionsReplies: 14Last Post: 10th Oct 2009, 07:00 -
AUDIO_TS file is empty
By LaNoche in forum ffmpegX general discussionReplies: 6Last Post: 20th Mar 2009, 19:35 -
HELP!!. . .DVD Without AUDIO_TS Folder???!!!!
By sniperloc in forum Authoring (DVD)Replies: 13Last Post: 17th Feb 2009, 12:29 -
Another folder than Video_ts and Audio_ts
By claudiofran in forum Authoring (DVD)Replies: 12Last Post: 3rd Mar 2008, 13:39 -
No Audio_TS files?? HELP!!
By onlyoneman in forum Authoring (DVD)Replies: 5Last Post: 8th Jan 2008, 11:19
