  1. Hello, this is my problem. I got ACEDVio but I dont know in what field order this board capture, is it UPPER or LOWER, how to find out that.
    I sent email to tech support but still no answer.
    It any software which can import captured file and to analize it and snow me field order.
    Thanks a lot
    Nov 2003
    Hellas (Greece)
    You could try encoding a small file with one setting and if it comes out jerky, then use the other setting.
    Usually, PAL uses "UPPER/Top field first" and NTSC "LOWER/Bottom field first".
  3. Another option is to simply load the vid file into TMPGenc - using it's wizard. The 2nd wizard page will show you which field order was capped.
    Nov 2003
    Hellas (Greece)
    I think TMPGEnc is NOT really good at determinig this specific setting. I may be wrong though.
  5. Well I am using PAL signal, but ACEDVio have FW and analog inputs
    If I capture using FW its probably lower field since it is a DV material and DV is almost always lower field.
    I dont know field order for analog inputs, and if they are upper, that mean that I can not mix them?
    Any suggestion
  6. Many a time TMPGEnc has got the field order wrong for me, resulting in jerky videos. So for me it's just pot luck, but usually as I'm PAL it's A first.
    Nov 2003
    Hellas (Greece)
    Any suggestion
    I'm sorry I cannot be of more help here. I thought you were talking about analog video. I have no idea what the deal is with DV (have never used DV so far).
    Best regards...
