Hi, I rebuild my PC and I tried to install the Latest version: SVCD2DVD v1.51.2 on my it. I followed the original email I got when I registered my version such as extracting BeSweet to the directory and place the xml file I received. When I tried to launch the program, it didn't do anything. I didn't get the registration window pops up as described on the website. Did I do something wrong? Is there new instructions? I am using the same xml file, is it okay? Please advise. Thank you very much.
OK..You need to go Here and download the latest version again. Install as normal inc the XML file and then run the program this will then promt you to go to a link to collect another reg file. DO NOT SHUT THIS DOWN UNTIL FINISHED...or you will use up one of your 2 installs.
Not bothered by small problems...
Spend a night alone with a mosquito
ffmpegx.com installation
By a.fritz in forum Video ConversionReplies: 1Last Post: 16th Jan 2011, 23:38 -
repair installation
By butterflies in forum Software PlayingReplies: 4Last Post: 6th Dec 2009, 06:24 -
installation on vista
By cadozz in forum SVCD2DVD & VOB2MPGReplies: 2Last Post: 5th Nov 2009, 22:24 -
Installation error -
By ruggerjvd in forum ffmpegX general discussionReplies: 4Last Post: 12th Nov 2007, 09:06 -
installation problem
By gokes in forum ffmpegX general discussionReplies: 1Last Post: 10th Jun 2007, 03:55
