im new to the DV cam scene. can someone tell me what a good make/model is for a DV camera?
i dont need top of the line. i need something that has good performance for a reasonable price, a bargain i guess.
thanks in advance.
Results 1 to 13 of 13
I have a Sony TRV-33 and Love it. The TRV-19 and 22 are also very good...and less expensive.
I love my TRV350 and it was really really cheap because it is D8 rather than miniDV.
Seems that Sony DVcams are considered overall the best (in the consumer category at least). Keep in mind that an inexpensive miniDV Samsung may do a very good job as well. Read some reviews at dvspot.com as well as other sites like camcorderinfo.com. Generally you get what you pay for, more money = better quality and features. Panasonic, Sharp, Canon are also nice cams (but generally with worse then Sony low light performance). When you decide what to buy read users feedback at epinions.com (may be an excellent point to start your search as well). Digital8 (Sony's proprietary format) is inexpensive and gives excellent quality. MiniDV is more expensive, smaller, lighter but also performs worse in low light (smaller CCD and optics) then Digital8 cams. Determine how much you want to spend and do your research. I own Sony DCR-PC1 and have no complaints altgough a 3CCD cam would certainly be better...
Sony cams considered the best?? Maybe by people who dont know better. Canon ones are.
Although the Sony camera line has the most models, lots of them can be disregarded as hopeless in terms of optics and performance.
I have a GL2 and have used and owned a number of Epson and Sony Minidv and 8mm cameras and while the Sonys have had lots of features, I found them to be underwhelming in the optics and image sensor dept. Now, where Sony does do well is in the > $1000 range when they start paying attention to the basics. The TRV950 is a good camera and so is the VXxxxx range. Their broadcast and ENG cameras are considered excellent too.
Personally I recommend the GL2 and the XL1S and the vx2000 and TRV950. While they do cost more - you really do get excellent results. I have no experience with the JVC and the other brands but I expect the same to hold true. -
i agree canon makes the best cameras. i have used a gl2, and it is one sweet camera. im still saving up for an xl1s though. anyone have 3 grand they want to let me borrow?
I, too, own a GL2. It is an excellent camcorder, lots of manual options.
Go GL2...
vcdlover -
Should I get a Sony TRV33 or DVD200 ?
I can afford the higher DVD200 price, but is it worthy ?
Is it a "strong" camera ?
If it shakes a bit - say you're on a bus or train - does it still work properly ?
Thanks,
Zetti -
Mine is the TRV14, same as the US TRV19 without passthrough.
Superb, except for the wind noise
Willtgpo, my real dad, told me to make a maximum of 5,806 posts on vcdhelp.com in one lifetime. So I have. -
Originally Posted by triphop
I'm not discounting other makers but Sony's cams popularity and overall good quality seems to be a common knowledge.
Ironically, 2 out of 4 cams you recommend are Sony products.
@Zetti TRV33 seems to be a better option. DVD200 CCD element is a bit smaller (affects low light perf.). DVD200 may be more convenient to use but I personally doubt if its DVD writer will last you longer then 3 years (still unproven technology). -
proxyx99
I kind of agree with you that most recommandations are for SONY and I see the quality myself. I chose GL2 over VX2001 because GL2 has 20X zoom vs. 12X and several hundred dallars cheaper. Other that that, I would jump right on VX2001. But GL2 meets my expectation so far.
vcdlover -
I also gotten the Sony TRV-350 camera mainly for A & D conversion of my Hi-8 and 8mm tapes to DV, as well to have a starting camcorder, but I do want to save up for a more professional camera....Ive heard alot of good reviews about the Canon GL2 model. Thing that bothers me is that it takes forever to save up for something like that and by the time you are finally ready to buy it then all of a sudden its no longer avaliable
Like its our fault that we cant find a job that pays enough to afford these things lol.
VTMI have the staff of power, now it's up to me to use it to its full potential to command my life and be successful. -
I hear you - I maxed out my CC and had to work lots of hours to pay it off - lifes a b*itch
Anyway at the GL2 pricepoint, you will find that cameras don't change often and tech does not get obsoleted every other month. Additionally, the optics and ergonomics are not something that moves that fast. The rest is just sugar
Time for an HD cam.. Last cam was Pana. DVC80.. Next will be?
By sdsumike619 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 17Last Post: 25th Nov 2011, 18:35 -
How to increase when TC OR CAM DVD to Tc or Cam rip
By antonymaheshca in forum Newbie / General discussionsReplies: 3Last Post: 12th Dec 2010, 13:42 -
Good basic vid editor that can handle .mp4 movies from FujiFilm S2000HD cam
By coffeecup-sf in forum EditingReplies: 3Last Post: 21st Jun 2010, 22:24 -
What are Good software i can use to record videos with my web cam or camera
By jace89 in forum Capturing and VCRReplies: 0Last Post: 21st Dec 2008, 15:08 -
Good Starter Cam in a tight budget?
By acid_burn in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 12Last Post: 3rd Aug 2007, 23:48
