I installed an ADS Pyro 1394 card, but then Internet Explorer wont work.
If I shut down and remove the card, run system restore it works again.
Anyone else have this prob?
do you really mean your networking doesnt work ?
if so -- try putting the firewire or network card in another slot .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
WinMe and WinXP have a function to network PC's over firewire. Internet explorer is probably trying to use the wrong network adapter.
Put your card back in and then check network properties. Has anything changed? -
Go into your Windows hardware setup (Control Panel, System, Device Manager) and see what drivers have been installed for the card. If there is a 1394 driver installed under Network Adapters, disable it. Don't remove it, since Windows may try to reinstall it next time you boot up. You should only have a driver for 1394 card under the "IEEE 1394 Bus host controller" categoryOriginally Posted by mrbmp
ADS Pyro A/V Link - Firmware u/g to fix VHS dropped frames
By pbanders in forum Capturing and VCRReplies: 16Last Post: 24th Mar 2011, 23:40 -
ADS Pyro A/V Link - black screen
By Brad in forum Capturing and VCRReplies: 10Last Post: 20th Oct 2010, 20:23 -
Motherboard Firewire versus Add-in Card Firewire
By SCDVD in forum Newbie / General discussionsReplies: 7Last Post: 19th Jun 2008, 12:19 -
Does current ADStech Pyro (firewire) w/Premiere still drop lots of frames?
By miamicanes in forum Capturing and VCRReplies: 9Last Post: 20th Sep 2007, 00:41 -
What Firewire Card for a Camcorder?
By rakun in forum ComputerReplies: 5Last Post: 12th May 2007, 10:20
