  1. i had never had a problem extracting an avi audio using virtualdub before. Today I tried to extract the audio off this avi but VDub wouldn't let me do it and pop up an error message.
  2. Member teegee420's Avatar
    Dec 2003
    Southern California
    What is the error message you received?
  3. here the message.
  4. Go to http://agrgic.tripod.com/avi2wav/ ang get the freeware avi2wav extractor , this will do it for you as i too had to extract the audio for encoding but was having difficulty in doing this too and found this works a treat.
    Then being ac3 i assume you want to convert this to 2 channel audio , rename .wav file to .ac3 then decompress with your fave decompressor mine being ac3 decoder available from http://www.mediatwins.com/products/ac3_decoder.htm. This i found to be the easiest with no probs whatsoever ( ever tried to figure BeSweet ? )
    8)
  5. thanks, chopster. it work like a charm.
