I've just got Nero Recode 2 to try and convert some SVCD mpg files into mpg4 files.
How do I do this in Nero Recode 2? It seems to only let you import DVD .vob files, and nothing else.
Can I use the the Nero Digital codec with another prog, such as TMPGenc?
TIA
Mark
He who dares, Rodders, he who dares -
You would need to author the SVCD's mpg file. Since the SVCD probably uses 480x480 you have a problem. You could demux the mpg into it's elementary m2v and mp2 streams. IFOEDIT's DVD author option can create DVD files from those streams. It will correct the headers to display the video properly and it will author from the mp2's 44100 sample rate and the resulting file will play in PowerDVD and will play on most DVD players if burnt to DVD-R.
Not sure if Recode would except the files but it's certainly worth a try. -
I tried what wulf109 suggested once before and those efforts were unsuccessful. I authored a DVD ISO, mounted to a virtual drive and tried to import the DVD into Recode 2. The titles imported just fine, it just didn't encode a single frame. I think it's still worth giving a shot though. Maybe you'll have better luck than I did.
Nero Digital VS X264
By mohawkcr in forum Video ConversionReplies: 4Last Post: 21st Dec 2010, 15:27 -
Nero Recode 3.1.2.0 -- "Nero Digital Standard" vs. "Nero Dig
By GrayStrickland in forum DVD RippingReplies: 1Last Post: 15th Dec 2008, 19:23 -
How can I convert MPG file recorded by progDVB into a regular MPG
By Aafour in forum DVB / IPTVReplies: 8Last Post: 16th Oct 2008, 13:51 -
Nero Recode/Nero Digital users...
By siratfus in forum Video ConversionReplies: 4Last Post: 31st May 2007, 05:06 -
Spliting large mpg file into clips and saving each clip as a mpg file ?
By denise4gb in forum EditingReplies: 1Last Post: 6th May 2007, 17:52
