Hi. I am making a DVD and I downloaded some trailers that I can put onto the DVD as extras. :P The trailers are in standard VCD format, which is 352x240. Is it possible to put it on the DVD?
Also, is there a program that can play small clips like this via a still menu where you click on a picture/button, and the clip plays? Then after it finishes playing, the menu you were once on pops up again?
Yes, you can use 352x240 if it is 29,97 fps.
TMPGenc DVD Author or DVD lab can import it and also convert the audio to standard dvd audio(48khz). -
Thanks, it is.
So does anyone know a program that can make a menu and play the clip?
Should be able to use the same prog Baldrick referred you to.
Boy do I love my avatar! -
As an aside you sometimes need to demux the MPG and re-encode the audio to 48khz. There's a max supported bitrate for MPEG1 video (but I forget what it is
) and there's some debate about the resolution. 352x240 is supported, but 352x480 and 720x480 might be supported too. In any event, they work on most standalones...
The max supported bitate is 1.856Mbps for mpeg1 on DVD.
There is no debate at all about the supported resolution for mpeg1 on DVD. The only supported resolutions are 352x240 and 352x288.
http://www.mpeg.org/MPEG/DVD/Book_B/Video.html
http://www.dvddemystified.com/dvdfaq.html
352x480/576, 704x480/576, and 720x480/576 are only supported when using mpeg2. 352x240/288 can be used with either mpeg1 or mpeg2.
VCD/Mpeg1 to DVD/Mpeg2 - tools?
By shira in forum Video ConversionReplies: 5Last Post: 5th Jan 2011, 21:49 -
Poor DVD quality: Computer screen recorded to DVD (mpeg1)
By MC123 in forum MacReplies: 6Last Post: 3rd Feb 2008, 16:33 -
dvd to mpeg1
By videogirl in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 20:26 -
Mpeg1 to DVD, problems abound - help, please
By Neisse in forum Video ConversionReplies: 6Last Post: 8th Jul 2007, 18:23 -
mpeg1-(VCD) to DVD w subtitles - possible?? Help please!
By nbarzgar in forum Authoring (DVD)Replies: 25Last Post: 28th Jun 2007, 19:30
