I have somehow amassed a load of different programs for capturing, editing and (I believe) posting to DVD. I’ve been tinkering around with different programs and I was hoping I could get input from experienced users on what program to use for what function. I have the following setup:
Hardware:
P4 3.06
512 dual channel RAM
ATI AIW 128
Firewire card
Sony TRV 250 Camcorder
Software:
ATI’s software MMC 8 (I think)
Pinnacle Studio 8
ULead VideoStudio 6 SE Basic
Adobe Premiere 6.5
VirtualDub
I will be doing two different things:
1.) Downloading video from my TRV250, making very simple cuts and maybe add titles then Burn to DVD.
2.) Download old VHS video, make the same edits and publish to DVD.
So far I’ve read LoardSurfs suggestions on capturing using the MMC TV recorder. But to be honest, I’m still pretty overwhelmed by the options.
Should I capture using Firewire to an AVI format or go right to an MPG format and at what resolution and what compression if any for the new Digital video and use the S-Video for the VHS stuff?
Should I edit using ????? program?
I should publish with what program and at what resolution for 4:3 TV viewing?
Thanks,
p.s What is a .m2v file and why when I publish to DVD with Premiere does it create 2 different files M2V and Wav?
Originally Posted by Nozmo
VirtualDub is as good an editor as there is out there. Go with it.
Your question about 4:3....that's just an aspect ratio. You can use whatever program you want to encode at whatever resolution you wish, just makes sure to check the aspect ratio setting. This is something that is done durring the encode process. Publishing - or authoring - isn't where you make this setting.
Your question about compression & frame size....use a bitrate calculator. Which settigs are best will depend on how long your movies are.
The two files being outputted by Premiere are elementary streams. You will need to convert the WAV file to MP2 or AC3 and then multiplex the resulting stream with the video file. This can be done either before or durring the authoring process, depending on what software you choose to author with.
HTH
One set of programs
By RBCC in forum Authoring (DVD)Replies: 4Last Post: 25th Feb 2012, 04:50 -
Can't open MKV file ripped from DVD - Plays in VLC but not in edit programs
By dsunbury in forum DVD RippingReplies: 3Last Post: 7th Apr 2011, 05:21 -
How to Publish Flash Videos in Your Personal Home Page?
By Nitemare in forum Video ConversionReplies: 1Last Post: 7th Nov 2008, 01:37 -
How to publish flash in google blogs
By SearchQuality in forum Video Streaming DownloadingReplies: 1Last Post: 25th Sep 2008, 14:55 -
Looking for a site to publish my dvds
By Random490 in forum Authoring (DVD)Replies: 2Last Post: 14th May 2008, 22:33
