Hello boys and girls
I have a mini problem. Wene i load my dvd in PowerDVD it plays like it should but wene i burn it and trie to see it on my dvd he stops on Title 3 (that is the first play title on the dvd), and i cant use the remote to press menu or anything else. I did use IFOEDiT to fix so that instead for playing the 2.0 sound he jumps and plays the 5.1 sound. But that cant be the problem. Also when using IFOEDiT to play the movie it stops on Title 3, until u press the menu button and select root menu.
Please help i dont wanna blow another dvd on this problem.
thx USiT
If you want to strip the 2.0 sound, use DVD shrink instead, it's easier to use and it's free.
Problem editing IFO using IFOedit
By cooldude859 in forum Newbie / General discussionsReplies: 4Last Post: 5th Nov 2009, 17:54 -
Changing a 4:3 menu to 16:9 using ifoedit
By NBninja8 in forum Authoring (DVD)Replies: 4Last Post: 20th Jan 2009, 21:11 -
FAVC Menu Problem
By marioval in forum Authoring (DVD)Replies: 1Last Post: 6th Feb 2008, 06:05 -
Menu swapping with IfoEdit - Problem solved
By Bingo-days in forum Authoring (DVD)Replies: 0Last Post: 22nd Dec 2007, 04:07 -
Menu Aspect Problem
By meeky in forum SVCD2DVD & VOB2MPGReplies: 3Last Post: 24th Sep 2007, 05:09
