Can't get the video of any of my mpegs (ATI MMC8.8 captures) to show in the Input monitor - but audio plays fine. Have tried to select via the Proj Manager & by drag/drop from Explorer. Mpegs seem fine when dropped onto the Output monitor/timeline. They also are ok with mpg2vcr, Media Player, & PowerDVD. Weird.
Any ideas?
TIA
Edit: Well, I've found some of my mpegs DO show in the Input Monitor now, but still haven't a clue why most don't...
Problem resolved.
For the record: I tried MVW on my "capture" machine & had no video problems there. I had originally loaded MVW on a fresh install of W2ksp4 on a test box along with several other edit/author trials. So reinstalled it. Same "no video" problem. Sent off e-mail to Womble last night. Got a request for sample mpg this morning. When I fired up the test box, no more problem. Not the first time a problem "solved" by a reinstall & reboot.
Should have tried that earlier. Weird symptoms though.
Cut Out Segments Of Video Using Womble MPEG Video Wizard DVD
By luckyace in forum Newbie / General discussionsReplies: 2Last Post: 4th May 2017, 04:46 -
Womble MPEG Video Wizard DVD is re-encoding video, claiming not to (FIXED)
By Brad in forum Authoring (DVD)Replies: 11Last Post: 2nd Mar 2012, 21:28 -
By newshoes in forum Software PlayingReplies: 10Last Post: 20th Mar 2008, 11:22 -
Womble MPEG Video Wizard - adding video files to dvd maker help?
By nightrider in forum Authoring (DVD)Replies: 3Last Post: 5th Mar 2008, 09:52 -
How to use Mpeg Video Wizard
By windranger in forum Newbie / General discussionsReplies: 3Last Post: 3rd Nov 2007, 09:24
