I was wondering if there is a way to make your own buttons in tmpgenc dvd author? Also how to get rid of the play all button? I would like to design my own background page and have a play and chapters and all the other buttons that blend in with the theme of the background and not the default one's you have to choose from. thanks
You can create your own images to use as buttons, backgrounds, etc. Simply goto create menu, select edit theme and select the layout you wish and then edit that layout. Click on the background and a requester opens and you can selct a file - jpg, bmp, psd, mpg. You can do this with buttons, backgrounds, etc. - still or video. Create a background image, go to TMPGenc and select the image and select an audio source and encode - you can then select this Mpeg video as your background in TDA and you have background audio.
Play around with it; is is simple once you get into it.
I should add, you must create your images in another program, such as Photoshop, Paintshop, etc. - even DVDlab
TDA errors
By siluet in forum Newbie / General discussionsReplies: 4Last Post: 17th Sep 2009, 08:08 -
TDA 4 Demo
By pepegot1 in forum Authoring (DVD)Replies: 0Last Post: 15th Feb 2009, 12:21 -
Is it possible to make animated buttons and info box?
By leffe in forum Authoring (DVD)Replies: 5Last Post: 17th Sep 2007, 18:53 -
reauthoring TDA video in TDA throws audio off
By spiritgumm in forum Authoring (DVD)Replies: 8Last Post: 14th Sep 2007, 19:04 -
Can you remove buttons from TDA?
By colt4523 in forum Authoring (DVD)Replies: 3Last Post: 12th Jul 2007, 04:51
