I've been converting a lot of my DVDs to divx so I can watch on my laptop. For the most part ffmpegx works great, but when I try any DVD from the * Collection I get info above the open dialog such as:
VIDEO: mpeg-2, size: 720x480, 29.970 fps, 9800 kbps.
But when I click "Play" mplayer exits immediately. I also can't preview from the Filters tab and no matter which encoding options I choose, it writes a 0 Kb file and ends immediately.
I've narrowed it down to only * Collection DVDs, all others work perfectly. I can play the VIDEO_TS folder off my drive using either VLC or Apple DVD Player. I have 3 different *C DVDs that have the same problem, below is the Process Information when I try to convert *.
Any Ideas?? Thanks so much for all the effort. Other than a few DVDs it works great!
Sat Feb 7 16:53:59 EST 2004
Using GNU internationalization
Original domain: messages
Original dirname: /sw/share/locale
Current domain: mplayer
Current dirname: /usr/local/share/locale
MEncoder dev-CVS-030226-15:00-3.1 (C) 2000-2003 Arpad Gereoffy (see DOCS)
AltiVec found
Reading /Users/jeff/.mplayer/codecs.conf: Reading /usr/local/etc/mplayer/codecs.conf: Using built-in default codecs.conf
File not found: 'frameno.avi'
libdvdread: Couldn't find device name.
The selected video_out device is incompatible with this codec.
Reading disc structure, please wait...
There are 15 titles on this DVD.
There are 1 chapters in this DVD title.
There are 1 angles in this DVD title.
DVD successfully opened.
success: format: 0 data: 0x0 - 0x3000
MPEG-PS file format detected.
MPEG: No audio stream found -> no sound.
VIDEO: MPEG2 720x480 (aspect 2) 29.97 fps 12250.0 kbps (1531.2 kbyte/s)
[V] filefmt:2 fourcc:0x10000002 size:720x480 fps:29.97 ftime:=0.0334
Opening video filter: [expand=-1:-1:-1:-1:1]
Expand: -1 x -1, -1 ; -1 (-1=autodetect) osd: 1
Opening video filter: [scale=352:224]
Opening video decoder: [mpegpes] MPEG 1/2 Video passthrough
VDec: vo config request - 720 x 480 (preferred csp: Mpeg PES)
VDecoder init failed
Opening video decoder: [libmpeg2] MPEG 1/2 Video decoder v2.0
libmpeg2: No accelerated IDCT transform found
libmpeg2: No accelerated motion compensation found
VDec: vo config request - 720 x 480 (preferred csp: Planar YV12)
VDec: using Planar YV12 as output csp (no 0)
Movie-Aspect is 1.33:1 - prescaling to correct movie aspect.
SwScaler: reducing / aligning filtersize 2 -> 2
SwScaler: FAST_BILINEAR scaler, from Planar YV12 to Planar YV12 using C
videocodec: libavcodec (352x224 fourcc=58564944 [XVID])
Selected video codec: [mpeg12] vfm:libmpeg2 (MPEG 1 or 2 (libmpeg2))
Writing AVI header...
New_Face failed. Maybe the font path is wrong.
Please supply the text font file (~/.mplayer/subfont.ttf).
subtitle font: load_sub_face failed.
Writing AVI index...
Fixing AVI header...
Video stream: 28.631 kbit/s (3578 bps) size: 1433 bytes 0.400 secs 13 frames
Encoding completed on Sat Feb 7 16:53:59 EST 2004
AnonymousGuest
AnonymousGuest
yes, same results.
AnonymousGuest
"fast DivX" Process Info:
Encoding started on Mon Feb 9 16:20:38 EST 2004
/Volumes/Macintosh HD/DVDBAK/*/VIDEO_TS: Unknown format
However, I can load that VIDEO_TS folder with no problems in both VLC and Apple DVD Player.
Problems with DVD burning for backup
By DDieggo1000 in forum Newbie / General discussionsReplies: 3Last Post: 2nd Jul 2009, 23:36 -
Problems with large (1 Tb) USB backup drives on older computers
By Toastie in forum Media Center PC / MediaCentersReplies: 10Last Post: 30th Apr 2009, 02:40 -
Space Chimps backup problems
By HmNtr in forum DVD RippingReplies: 3Last Post: 19th Dec 2008, 15:20 -
AutoGK - experiences and problems of ripping a larger movie collection
By vchrizz in forum DVD RippingReplies: 2Last Post: 22nd Sep 2008, 17:43 -
dvd backup problems
By RemainsHuman01 in forum DVD RippingReplies: 1Last Post: 20th Aug 2008, 00:15
