Results 1 to 10 of 10
  1. Hi ppl,
    I recently bought a couple of ex-rental DVD's from my local video hire shop and want to make backup's of them without the hardlock trailers (that play when I insert the disc) but I do want to keep the interactive menu's (extra's, scene selection etc).
    I am using DVD Shrink 3.1.3 at the mo and if i do a full backup then the trailers are still on, where'as if i do a "re-author" i cant keep the menu's and just end up with the main film. Does ne 1 know how I can keep the menu's but not have the trailers at the start.
    Thx
    :) "Janey is m' Sunshine" :)
  2. Member FulciLives's Avatar
    May 2003
    Pittsburgh, PA in the USA
    Originally Posted by Desperate Jip
    Hi ppl,
    Thx
    I think DVDShrink can be made to remove any and all restrictions. My guess is on the original you can't fast forward or skip these trailers but at least you SHOULD be able to do that on the back-up even though they will still be there.
    - John "FulciLives" Coleman
  3. My guess is on the original you can't fast forward or skip these trailers
    Thing is...i can skip these trailers on both the original and the "full backup" i made, but i just dont want the trailers at all, what i want is to put the disc in and have it load staight onto the main menu. Is there a way to do this m8...?
    P.S. how do you get the "Desperate Jip wrote" thingy when i just get "Quote" coz it dont say who im Quoting..?
    Thx Fulci
  4. Member FulciLives's Avatar
    May 2003
    Well I can't help you with the DVD thing but I can help you with the QUOTE thing ...
    When you reply hit QUOTE instead of reply or do this (without the beginning " and ending "):
    Originally Posted by username
    blah blah blah
    Insert the person's name where it says USERNAME
    It is THAT simple
    Now only if your other problem was so simple hehehe
  5. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Use IFOEdit to strip out the trailers. Do a web search for IFOEdit and Derrow and find his manual for IFOEdit - It gives you step by step instructions on how to do this.
    If in doubt, Google it.
  6. Originally Posted by FulciLives
    It is THAT simple
    Cheers Fulci m8, n1...hope I can sort the other 1 out...LOL
  7. Originally Posted by jimmalenko
    n1 m8 ...I'll give that a go and post my results
  8. Hehe, Thx jimmalenko...I got IFOEdit and got stuck into the guide and now i have it sorted, Thx again m8
  9. VH Veteran jimmalenko's Avatar
    Aug 2003
    Down under
    Happy to help !
  10. Originally Posted by jimmalenko
    Never approach a computer thinking "This will only take 5 minutes"
    u can say that again
