  1. Rookie question here. Is it possible to take a PCI device (e.g., a PCI capture card) and put it in an external enclosure for portability? Asking because I own a capture card but wanted to be able to transport it to/from work. If these things don't exist, how hard would it be to build one?
  2. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    I don't even know how to begin answering that one
    Is this capture card simply a FireWire card or is it something akin to an expensive hardware encoder?
  3. Member The village idiot's Avatar
    Apr 2002
    Adrift among the STUPID
    http://www.google.com/search?hl=en&ie=ISO-8859-1&q=pci+extender
    from google:
    http://www.mobl.com/expansion/pci/
    Looks like the one you are looking for is not exactly portable. Avid used a similar box when apple made the G3's with only 3 or 4 PCI slots, a great big box for 6 or more cards, with it's own power supply. I would also say that cheap is not going to be the word. Unless that card cost you more the about $500, it might be just as cost effective to buy another card and leave them installed in the 2 machines.
    check that here is the price list:
    http://www.mobl.com/expansion/pci/pdf/pci_exp_prices.pdf
    So unless your card cost around $3000, don't bother with these types of special purpose extensions.
    Hope is the trap the world sets for you every night when you go to sleep and the only reason you have to get up in the morning is the hope that this day, things will get better... But they never do, do they?
  4. It might be cheaper to just put a firewire card in all your machines and to use something like ADSTech PYRO AV Link.
    http://www.adstech.com/products/API-752/intro/api752intro.asp?pid=API-752
    Definately alot less time consuming!
  5. Originally Posted by rallynavvie
    It's a Hauppauge PVR-250 card. The reason I'm wondering if it's possible to put it in its own case is because I want a capture device that I can use that is portable from one computer to another (e.g., to another one of my computers here). I know there are portable MPEG-2 capture devices (I'm currently testing the ADS Instand DVD 2.0) but I like the Hauppauge card except that it's not easily portable.
  6. Member The village idiot's Avatar
    Apr 2002
  7. Originally Posted by mrmungus
    It is possible, but it is expensive. Hundreds for a PCI to PCMCIA convertor box. If you MUST have portability, getting a FW or USB2 device is a better option.
  8. contrarian rallynavvie's Avatar
    Minnesotan in Texas
    Yeah, I could see using it for the DV Storm since it's a $1200 card, but even then its a pretty expensive deal. I second the suggestion of getting a USB or FireWire device instead. You'll end up spending less than the PCI device you want.
