Hello,
I have asked this question earlier today on the audio forum and the newbie but sofar I didn't get the answer that will do the trick. So therefore I try here once more. Who can help me out?
I have an avi movie wich causes me a lot of trouble when I put it in the TMPGenc to make two streams to use in the IfoEdit. This trouble is: that TMPGenc import the video file but doesn't import the audio file.
I have had a same problem earlier wich I solved using VirtualDub. When I put that file in I got a message about VBR sound and that the program would fix that. But in this case VirtualDub doesn't react and normally import the file.
I have tried an other option to get a wav file from the movie (using avi to wav) and put this in TEMPGenc but this didn't work too. Also a single generated mpg2 file and (this) wav file together in the Ifoedit gave me after burning a movie without sound.
Who can help me out solving this matter? It seems to me that with all the newer videocompressors like Xvid this problem increases.
Thanks in advance for any help!
Hello ZippyP (and all others!),
It looks like this solution is working. At least I see a reaction at the source area in TEMPGenc and is very positive.
ZippyP, I know a lot of people deal with this problem when I looked over several sites according to this problem. It looks like you found a very nice solution. Thanks!
Rob -
I am having the same problem with an AVI, I have not used G-spot before but downloaded it and looked at the file. G-spot says I have all the right codecs installed, but I still can't get the audio off this .avi and when I try to render it with G-spot I get a partial failure message stating some of the streams in this movie are in an unsupported format.
Help
Nightwolf
Can't Import Video File with AC3 Audio into Vegas 9 Platinum
By Charlie_L in forum Newbie / General discussionsReplies: 11Last Post: 2nd Sep 2011, 07:44 -
Audio Sound File Saved - Canot Hear Sound - Total Recorder
By Teac23 in forum ComputerReplies: 1Last Post: 15th Apr 2011, 14:29 -
Why does this mpg file doesn't play sound in my divx player?
By Stealth3si in forum Newbie / General discussionsReplies: 15Last Post: 5th Jul 2009, 19:00 -
DGMPGDec plugin for AVISynth doesn't read MPEG file's audio
By Mark001 in forum Video ConversionReplies: 11Last Post: 9th Jun 2007, 18:07 -
ffmpeg doesn't reconize sound in video file.........
By ssj2_goha in forum Video ConversionReplies: 15Last Post: 18th May 2007, 15:38
