(01) First I encode the VOBs with Flask 0.6
(02) Then I have a large AVI (ap. 2-3,5 Gigs )
(03) After that I cut it in two pieces with VirtualDUB
(04) Then I encode this files with TMPegEnc 2.0 to SVCD
Using TooLame Encoder for Audio!
This worket until today!! Steps 1-3 worked, but after
TMPGEnc created the "temp. WAV" TMPEG exits and was it!!!
I'm sure I didn't change any config!
Can ne1 help ?
THX !!!
Results 1 to 10 of 10
I use only 12H and 12 (on some cases) and I have not a simply problem with toolame...
I had problems with 12j and 2.0. Sometimes, it shows that it is encoding audio, and encodes nothing!!!! -
Get the new AZID Lame GUI (by Danni Din), it has a section for tooLame and you can multiplex it afterwards
i try to use toolame as my alternative encoder but i failed. i downloaded from the site and extract everything in a folder i named 2lame. and in the TMPGE option i directed the exe file to be used as external encoder. well it said toolame exe file cannnot be used as external encoder. i checked on the exe file to see what's wrong and when i double click on the file a small dos window screen pops up and disappears. it almost flashes and nothing happens. no window opening, nothing. i still don't know what this toolame thing is. accept it truly is lame how it functions.
i use SCMPX..i used toolame and it stops at 89% of creating the tempoary wave file i say toolame is truely tooolame...use SCMPX it the best
I think I'll try this SCMPX Enc.
But I can't understand why tooLame is not working ... it worked! But hey! I testet a small DiVX 5 MB and then it worked!
Maybe there is an error when I cut the AVI ? -
SCMPX is good enough, though try loading up both segments of the avi in vdub and saving the wav file, then converting that.
The TooLame Enc. is better than the builtin of TMPG ? Much better??? Or only professionals hearable ?
Hi,
I think I know why it doesn't work ( TMPGEnc. & TooLam ) :
It might depend on how the AVI is cut !? I had another AVI, cut this ant TooLame is working!
Does anyone know more?
HC enc: Your settings ?
By themaster1 in forum RestorationReplies: 6Last Post: 21st Oct 2011, 20:55 -
ENC encoding versus no ENC encoding
By RL in forum ffmpegX general discussionReplies: 3Last Post: 4th Feb 2011, 18:44 -
New Kiss DejaVu Enc released
By slmnow in forum Latest Video NewsReplies: 0Last Post: 20th May 2008, 12:08 -
I have flv files I'm trying to recode but they have an enc file.
By watusi512 in forum Video ConversionReplies: 2Last Post: 17th Dec 2007, 20:59 -
Something better Tmpeg Enc
By 02fx4dude in forum Video ConversionReplies: 4Last Post: 15th Aug 2007, 07:23
