  1. Here are the programs I use for transforming
    DVDs onto VCDs. FOR decrypting: cladDVD.exe
    For frame servingVD2avi and finally for encoding
    TEMPGenc 2.5. It is whit this program I have a problem.
    He is supposed to encode my two files issued from the
    previous program ( DVD2avi ). Those two files are
    title ac3 t01_2ch (I believe it is an mp3 file) for sound
    and title .d2v for video. (I am not sure how you call these files avi? )
    After encoding I get a “film” in mpeg format.
    The video is of very good quality and the sound
    is perfect , the problem ….they are not synchronized
    I have tried a multitude of thing; play whit the settings,
    I `ve tried to adjust whit the audio gap setting and I`ve
    tried the latest version of the TTEMPGenc 2.5 plus.
    Nothing works! !
    Does anybody (probably somebody that had the problem before)
    has an idea what to do
    Or suggest me an other encoding program.
    Desperately yours
    Samui
    Jan 2003
    Down Under
    I don't know much about using those programs separately, but I downloaded DVD2SVCD and this is the easiest program to use.
    You already have TMPGEnc so give it a go. Personally it's best for SVCD over VCD but it may be better on your pc for VCD than mine.
