I've tried Nero 6 and Pinnacle Instant DVD (not on the system at the same time!) and Windows Movie Maker, all programs crash during the final burn process either to dvd or virtual drive at various % points. I've tried a program called EndItAll to close any programs that might have been running in the background, i've tried reg-cleaner and then re-installing. I've tried changing the performance settings as well ie. for best performance. It's starting to annoy me now.
Thanks if you can help...
Sytem info- Windows XP Pro, 2.6 AMD Athlon XP, NVidia GeForce 5200 FX, 256mg DDR Ram, MSI K-7 Motherboard, Pioneer A06 DVD RW+/-
No it's an ide cable, i've got it set as the master and a cd writer 'daisy-chained' as the slave on the same ide cable. Not exactly sure what raid is, apart from the fact it's a type of connection. I've heard it mentioned quite a bit, but it doesn't really mean anything to me.Thanks for your help...
Well, if the programs crash even when writing to a virtula drive, then I suspect it's more of a software problem than a hardware problem.
Uninstall all your burning software and then try them again.Regards,
Rob -
had a similar problem, turned out to be a conflict with another program installed. You'll have to remove progs in turn to find out which is causing the problem. I just formatted the h/d re loaded xp, nero & shrink, then each of my other progs in turn trying a burn each time.
no man (or woman) is an island.
Sony S580 region locking
By cheekiestgrin in forum DVD & Blu-ray PlayersReplies: 2Last Post: 2nd Oct 2011, 20:46 -
Help; Capture Locking Up with Canon Elura 90 DV
By bj4jc in forum Capturing and VCRReplies: 2Last Post: 22nd Nov 2010, 23:37 -
Slow & locking up
By BLSAMPLES in forum ComputerReplies: 7Last Post: 17th May 2010, 15:17 -
Why is DVD Decrypter locking up?
By dphirschler in forum DVD RippingReplies: 11Last Post: 14th Jan 2010, 22:34 -
Subrip2scc locking up?
By Lbrow in forum SubtitleReplies: 0Last Post: 12th Jul 2007, 15:08
