I did a similar post where I asked which do you think is going to be future standard but now I ask which do you like to use the best? ive expermented with both and I actully like + a lot better, ive had serval - disks mess up on me or dodgy writes, + has never caused me a problem also they look cleaner and crisper afterwards and nicer to look at when Ive put a label on them..... Ive used to - to record an entire american run of a popular american sitcom from my videos becuase I need 60+ disc and it was cheaper route but now I think im always going to use + .. whats you view?
DVD region settings are a joke, I can't believe how stupid people are falling for it
this question has all ready been asked a thousand times. do a form search and you will fine your answers.
How Big A Boy Are Ya? -
In the case of dual burners it's not so much the + or - but more likely the fact that certain media may work better with you writer. If you've had trouble with - then try another brand not just the name on the box but a different media id. The same would be true if the problem was with +.
With standalone players the above could also be true but in some cases + or - could matter especially with older generation players.
I've had some issues with - and my burner but they were firmware/ brand related. I've had issues with +rw but that was standalone player related. My player needed +rw to be set to book type dvd-rom. Once I got past the burner/media problems, the -R worked fine on the same player.
You should use whatever works best for you.
Which optical drive brand do you prefer?
By johns0 in forum PollsReplies: 18Last Post: 3rd Jan 2012, 21:55 -
Which file format does everyone prefer?
By kamelman in forum Newbie / General discussionsReplies: 11Last Post: 10th Sep 2011, 10:46 -
Which Direct-to-CD Printing Software Do You Use or Prefer?
By p_l in forum MediaReplies: 4Last Post: 27th Feb 2011, 20:52 -
Which of these drives do you prefer & where to get them?
By uncleB in forum DVD & Blu-ray WritersReplies: 7Last Post: 30th Jan 2008, 10:50 -
DV to - ?? Which format do you prefer.
By eroy in forum Video ConversionReplies: 1Last Post: 23rd Dec 2007, 11:58
