Hi
I have a *.cue file that is in SVCD of a *.mpg file, and I would like to convert it do *.avi.
I have VirtualDub MPEG2 but when I am converting it to *.avi an error message appears saying that an audio frame gives an error in minute 12:13. I can't fix this. (can I)
Anyway, wich is the best way to convert *that* to *.avi?![]()
I want to make it *.avi because I want to join the two CD's (yes, they are 2) and then convert to DVD.
Is there a way to join two *.mpg as easy as joining 2 *.avi with VirtualDub?![]()
.oO(hm, so many questions...)
Help me please.
Thanks,
Tiago.
The first thing you need to do is extract the mpegs from the .cue and .bin files. You can use ISObuster for said task. To join the mpegs you can use TMPGEnc(go to File>MPEG Tools>Merge&Cut) or Womble MPEG VCR. To convert to avi, stick with Virtualdub MPEG2 and make sure you de-interlace(assuming the mpegs are interlaced).
No, no, no!
Extract the two mpegs. (Use the method teegee420 describes)
Run them thru svcd2dvdmpg
Author as DVD.
Done.
No quality loss. No need to join. No need to reencode.
/Mats -
/MatsI want to make it *.avi because I want to join the two CD's (yes, they are 2) and then convert to DVD.
Well, there's TMPGEnc MPEG Tools... Then again, you might get sync problems...HOW TO JOIN 2 *.MPG FILES!!??
Womble MPEG VCR seems to be best at this, even if I haven't had the pleasure to try it myself...
/Mats
JPEG to AVI (or MPEG2) via timing cue-sheet?
By NetRodent in forum Video ConversionReplies: 0Last Post: 31st Aug 2008, 10:49 -
SVCD 704x480 mpg stills with audio?
By jungle5150 in forum Authoring (VCD/SVCD)Replies: 21Last Post: 29th Jul 2008, 17:28 -
I get ac3, mpg, mpg.s.mpg, .xml & .mpv instead of VIDEO_TS/DVD
By emanmb in forum ffmpegX general discussionReplies: 5Last Post: 18th Apr 2008, 15:48 -
Burning VCD/Svcd mpg files to dvd without encoding
By Morb1ous in forum Video ConversionReplies: 4Last Post: 22nd Aug 2007, 17:56 -
The FilmMachine Xvid to SVCD conversion not creating Bin/Cue files
By louv68 in forum Video ConversionReplies: 2Last Post: 24th Jul 2007, 10:11
