I recently bought a Fisher S1100 Dvd player. It was a great deal, and i love it dearly, however, when I went too play my SVCD's i found that the one's i had burned in NERO wouldn't work, they would just freeze 1 second into the svcd. I then tried my svcd's that i had burned from their cue/bin form, they worked fine. i tried useing VCDimager to change the svcd's i had burned useing nero into cue/bin, but i always get an error msg.
I know this is a broad question, but i hope someone can help me.
Nero...
Try using CDRWin to extract the offending disc to CUE/BIN format on your PC. Then, you can use VCDXRIP (tool in VCDImager) to extract everything and to create an XML descriptor file...
Editing/fix the XML (if necessary -- if your original SVCD had still menus created by Nero, then it is necessary).
Rebuild a CUE/BIN image with VCDXBUILD.
Burn with CDRWin, CDRDAO or Fireburner (but not Nero).
Alternatively, you could try simply extracting the MPEG-2 stream off the SVCD and then reauthor that onto a new SVCD with VCDImager.
Good luck.
Regards.
Michael Tam
w: Morsels of Evidence
Looking for info re three old VCRs - two JVC and one Fisher
By wiseant in forum Capturing and VCRReplies: 2Last Post: 23rd Jul 2024, 13:01 -
Cannot read Nero-burned CDR (Vista) on XP
By walter4h in forum ComputerReplies: 4Last Post: 27th Mar 2008, 02:20 -
Suddenly Nero SHowtime won't play DVDs that I've burned.
By ibzomie in forum Newbie / General discussionsReplies: 7Last Post: 20th Jan 2008, 01:13 -
Burned my first divx using Nero but they are not in sync
By Taylor in forum Newbie / General discussionsReplies: 6Last Post: 4th Sep 2007, 00:07 -
Can't copy a (ISO) DVD I just burned in Nero
By perceptionist in forum Newbie / General discussionsReplies: 5Last Post: 5th Jun 2007, 22:49
