I have a sony trv 620e video camera, that came with pinnacle studio dv and video capture card. I have down loaded and edited the film now I want to burn it on CD to play on my DVD player through the TV. I am new to this game any info you can give me I will be most great full. My CD writer is an LG using adaptec, easy CD creator.
Regds
<font size=-1>[ This Message was edited by: gib on 2001-10-20 10:51:51 ]</font>
K, make sure you captured the film at .mpeg format, its better and more sufficient, secondly, to play on ur dvd player your DVD player has to support CD-R and VCD, if it doesnt then u cant, and if your capture card had TV-out then u can view whats on ur cpu to your TV directly, but not getting out of topic, if your dvd does support CD-R and VCD, then burn the mpeg as VCD (mpeg-1) using WINONCD or Nero Burning Rom, or get VCDImagerGUI from the website and convert the mpeg to bin/cue and burn the iso with fireburner or cdrwin, if your still confused let me know, all i gotta say is good luck d00d and read this tutorial carefully
FastSnap:
* Capture video in mpeg
* convert to bin/cue with VCDImagerGUI
* or burn directly with WINONCD
* DVD must support CD-R and VCD
* use TV-OUT and use VCR to record with an VHS tape
* GOOD LUCK!!!!
Removed Esata drive and replaced with another drive. New drive is now unus
By cal_tony in forum ComputerReplies: 6Last Post: 7th Feb 2012, 14:17 -
DVD exploding inside the drive from a drive exceeding 24x. True?
By snafubaby in forum MediaReplies: 10Last Post: 5th Dec 2010, 18:05 -
Compress hard drive to save space/Index drive for faster searching?
By orfajackson in forum ComputerReplies: 3Last Post: 31st Aug 2009, 17:55 -
Time/Date Stamp - DVD, Hard Drive, and/or flash drive camcorders
By vanjh9 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 2nd Feb 2009, 18:38 -
Is It Possible to Make Multiple Drive Images on One External Hard Drive
By drstew in forum ComputerReplies: 17Last Post: 24th Nov 2007, 08:47
