How do you delete extra parts of a dvd that you dont want then use dvd shrink? I tried to reaurthor with dvd shrink but the cursor on the menus is missing. I was told you can delete parts then use dvd shrink. I looking through the guides but can find out how. Please help.
I'd like to extend the above DVD Shrink question...
I can re-author a DVD in DVD Shrink and de-select the EXTRAS folder, producing a DVDR with only the main title. However, when I don't de-select the Menus, I can't access any menus on the burned DVDR -- only the main title plays. Does the "EXTRAS" directory typically contain necessary files (beyond the actual 'extra' video bonus tracks and so forth) that are necessary for the menuing system to work?
Nevermind. Sorry. I found some answers elsewhere on this forum. -
Originally Posted by Tom Lewandowski
The only way to keep the menus is to use Back-Up Mode rather then the Re-Author mode. But then you have to keep almost everything (including subtitles). You can compress the dvd components at different levels though. There are also some programs like DVDStripper that you can use to remove FBI warnings, etc. prior to using DVDShrink. -
just use full back up mode and make everything you don't want into still pictures.
How Big A Boy Are Ya? -
Originally Posted by cmtar
If you use Re-Author mode the old menus are no longer linked to the new dvd.
You can do a lot of different things with IFOEdit as well. There's a bit of a learning curve with it though.
Deleting files and directories
By Jomapil in forum ComputerReplies: 11Last Post: 20th Mar 2012, 05:41 -
Deleting cookies?
By neworldman in forum ComputerReplies: 3Last Post: 21st Jun 2011, 12:52 -
Deleting subtitles from videos
By angeloslev in forum Video ConversionReplies: 1Last Post: 23rd Feb 2011, 21:33 -
Deleting Audio Tracks
By cmars in forum AudioReplies: 2Last Post: 28th Apr 2010, 09:00 -
Deleting Extras with BD Rebuilder
By wulf109 in forum Blu-ray RippingReplies: 0Last Post: 27th Dec 2009, 23:10
