I have VideoStudio 7 and authored a DVD where the audio/video sync is off. The source was a mpeg2 clip captured from my ATI AIW 128 pro at 352x480, 29.96 fps, 2451bit rate, mpeg audio, 44.1, 256. The clip plays perfectly. It does have dropped frames. When I use VideoStudio 7 to create the DVD I specifically specified the correct settings so it would not reencode. Now the DVD has an audio sync problem. Any ideas?
could ba a number of things, but noticed you said your audio was 44.1... dvd audio needs to be 48.
sorry. i confused myself. captured at 44.1, vs6 edited and saved as 48. so clip used by vs7 was 48.
An app to visually sync audio to video similar to Subtitle Edit visual sync
By cinesimon in forum AudioReplies: 3Last Post: 6th Sep 2011, 08:54 -
Audio/video/subtitle sync problem converting MKV to DVD (Muxman issue?)
By crackerbear in forum Authoring (DVD)Replies: 3Last Post: 7th May 2010, 12:23 -
Sample error on separate source means video & audio out of sync!
By christowe in forum MacReplies: 3Last Post: 13th Jan 2009, 14:22 -
MKV->DVD Audio/Video Sync Problem
By Maikeru-sama in forum Video ConversionReplies: 1Last Post: 16th Aug 2008, 19:32 -
Software to make sure the audio and video of a authored dvd are in sync?
By snafubaby in forum Authoring (DVD)Replies: 7Last Post: 1st Oct 2007, 08:13
