I used Nero to burn a VCD from a DivX AVi.- Everything went smooth except for the sound- Out of sync (approx 3 sec late)
Any suggestions?
Pick a number, your not the first.
There seems to be about 100 different suggestions here on the forum. Do a search in Conversion and read.
Are you letting Nero convert the movie for you, or are you using TMPGenc or other program to convert it to moeg first? -
My personal fix for this:
1- Demux the sound using VirtualDub (generate separate WAV)
2- Use TMPGEnc to encode the DIVX, using the WAV as separate audio input.
Burn the resulting file on Nero.
Works much better that way.
DIVX sound and video not in sync
By DarkPhoenix77 in forum MacReplies: 2Last Post: 27th Feb 2009, 12:48 -
Divx sound sync issues
By hotsalt in forum Video ConversionReplies: 1Last Post: 11th Apr 2008, 15:18 -
MPEG-1 to AVI DivX: No sound
By Waterman II in forum MacReplies: 0Last Post: 18th Sep 2007, 04:16 -
No sound when converting FLZ file to AVI DivX!
By zanyjudy in forum ffmpegX general discussionReplies: 3Last Post: 14th Sep 2007, 07:02 -
riverpast rm to avi conversion sound out of sync
By princevegetam in forum Video ConversionReplies: 9Last Post: 2nd Jul 2007, 03:45
