Hello,
I have an avi movie wich causes me a lot of trouble when I put it in the TMPGenc to make two streams to use in the IfoEdit. This trouble is: that TMPGenc import the video file but doesn't import the audio file.
I have had a same problem earlier wich I solved using VirtualDub. When I put that file in I got a message about VBR sound and that the program would fix that. But in this case VirtualDub doesn't react and normally import the file.
I have tried an other option to get a wav file from the movie (using avi to wav) and put this in TEMPGenc but this didn't work too. Also a single generated mpg2 file and (this) wav file together in the Ifoedit gave me after burning a movie without sound.
Who can help me out solving this matter? It seems to me that with all the newer videocompressors like Xvid this problem increases.
Thanks in advance for any help!
Closed Thread
https://www.videohelp.com/forum/userguides/140703.php
Check this for ac3 conversion which your audio might be.
Annoying popping sound after converting AVI to DVD
By Smudge249 in forum Video ConversionReplies: 2Last Post: 13th Oct 2009, 17:24 -
Converting WAV/MP3 to DVD-compatible sound file
By Erasmus in forum Authoring (DVD)Replies: 8Last Post: 6th Apr 2009, 22:41 -
Sound problem when converting AVI to DVD
By luvflt in forum Newbie / General discussionsReplies: 1Last Post: 9th Feb 2009, 18:12 -
No sound when converting DVD (VIDEO_TS)
By jompa in forum ffmpegX general discussionReplies: 3Last Post: 18th Oct 2007, 17:48 -
Sound popping after converting PAL AVI to NTSC DVD using DVDFlick
By embreeb in forum Video ConversionReplies: 3Last Post: 25th Sep 2007, 11:46
