I'm new with a fresh 106D, and I'm encountering a recurrent problem when burning to CD-Rs. At the start of a burn, the drive spins really fast, then really slow, then fast, then slow, etc. until I turn it off. I'm generating a lot of coasters like this. It only happens with CDs, it makes DVDs just fine. Is this a known problem with the 106s? Or do I have a lemon?
I have the Pioneer DVR-106D at it's great with CD-R's are you using the Buffer Underun protection at all ?
Hello,
My new Pioneer A06 is doing well as far as DVD bruning concerned.
BUT! I'm not able to write CD's.
I'm using Nero 6 (under W2K) and did all the things you do when you have a troubling piece of software. I updated, made clean install, removed other burning software, cleaned the register, and controlled my ASPI.
Still no luck! Nero is doing well until the burning process begins. Sometimes it crashes with a logfile in DrWatson, sometimes Nero just disappears without any mention of an error.
The writer is at secondary master and I did not mess up with the master/slave jumper.
Please help me!
TIA
Jan-Hein de Wit
Annoying video/audio sync problem
By WebMaximus in forum DVD RippingReplies: 2Last Post: 12th Nov 2011, 08:59 -
I have an annoying problem with my dvd burner.
By roomgrey in forum DVD & Blu-ray WritersReplies: 6Last Post: 19th Oct 2010, 14:43 -
Got a really annoying problem, avi sync problem
By burnleylad in forum Newbie / General discussionsReplies: 10Last Post: 8th Apr 2010, 11:31 -
Annoying blackscreen problem with AVS video editor
By in flames in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2007, 00:10 -
Pioneer 106D & Maxell 8x DVD-R
By piano632 in forum DVD & Blu-ray WritersReplies: 1Last Post: 22nd Jun 2007, 18:38
