  1. I don't know why its skipping when I'm playing it on my DVD player? Does the speed of writing matter? I tried burning it at 32x but that didnt work. I will try to burn at 4x and see how that goes. Is there something I need to do? what am I doing wrong?
  2. bad quality media, cheap ass dvd player, out of spec svcd..
  3. dvd player is jvc...so its not the dvd player. My friend burned it and it work fine on his dvd player and his dvd player is a norcent some cheap ass brand. He told me that he set his to burn to play on his dvd player.
    Dec 2003
    Glasgow , United Kingdom
    A whole load of reasons , this seems to happen with burnt SVCD's it seems some players have problems keeping up with the higher bitrates of SVCD's especially when trying to read off CD-R's however even on cheap players the skips should be very minimal . All that can be suggested is to slightly lower the maximum bitrate of the SVCD minimising the problem .
  5. I burned several svcd and xsvcd and I noticed that media burned too fast and to high a bit rate can cause a dvd player to jump and have blocking in the playback.
    Slow down your burn should help. Author on a cdrw to test and that way you are not creating coasters while you experiment to find the right combination.
    As far as bitrates, check your specs against this boards review/specs of your dvd player. This site is fantastic for researching just what will play on what dvd player.
    Good luck.
