I wanted to know what is involved in a DVD player that lets it play specific formats and not another? Some will play VCD, but not SVCD or DVD-R, but not DVD+R. Does the firmware control what formats can be played or is it physical decoders, or possibly a mix? Is there a DVD player that plays all out of the box or a player that can be upgraded with a new firmware that will allow you to play all/most formats?
There are lots of dvd players that play everything, mostly the cheap ones. I'm in OZ but I'm sure if you asked in the shops in Texas for what you want, they would point you in the right direction.
"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey -
Nothing plays "everything". Your best bet is to buy a good quality brand name and a elcheapo Chinese player.
As to your Q. The answer is a mix.
- Encoder type
- board firmware
- drive firmware
- license from format copyright holders -
actually, there is a better way.. its called the pioneer dv-260(s)
there isnt a macrovision/region hack that i know of.. but this dvd player is KICK ASS..
its plays, vcd/svcd/xvcd/xsvcd/dvd-r/dvd+r/dvd-rw/dvd+rw/mp3/wma/jpg
(i think there is a conversion kit so it will play vinyl too, heh)
it even converts pal to ntsc.. and it also has menu navigation buttons on the player itself, should you lose your remote.
it plays cheap cd-r's & dvdr's.
and its not a cheap ass foreign dvd player that'll crap out on your in a couple of months.
its under $80 at walmart..
the dv-250 is alright, buuuut no dvd navigation buttons on the dvd player and it wont convert pal dvd's to ntsc (it does for s/vcd though, wierd)... -
Originally Posted by offline"Whenever I need to "get away,'' I just get away in my mind. I go to my imaginary spot, where the beach is perfect and the water is perfect and the weather is perfect. The only bad thing there are the flies. They're terrible!" Jack Handey
Well, Sorry, Mine plays cd,svcd,vcd,dvd+r,dvd-r, dvdrw+-, mp3,jpeg
Never tried RAM or VOB's or AVI as most movies around are not in that format. Maybe that's common in the states.
Formats that will play on DVD player to TV
By humpybong in forum Video ConversionReplies: 5Last Post: 15th Aug 2010, 01:32 -
Mixing File Formats on One DVD
By OldGuyWhoBurns in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jun 2010, 08:17 -
Video formats to dvd
By Illusionist in forum Newbie / General discussionsReplies: 2Last Post: 3rd Nov 2009, 12:51 -
How do I convert various formats TO a dvd that will play on ANY dvd player?
By tinman01 in forum DVD RippingReplies: 11Last Post: 10th May 2009, 12:10 -
DVD Formats
By Bluenote58 in forum MediaReplies: 9Last Post: 30th Sep 2007, 05:23
