hey,
a friend's just sent me a few CDs full of very cool m2v videos that i'd like to convert/burn onto DVD-R. i've done this before with other formats but have no idea what to do wuth these m2v files.
i tried searching the site but didn't find an answer. can anyone of you suggest a solution ?
thanks![]()
M2v files are the video part of mpg2 files,do the files you have got sound cause they might be misnamed?
they have sounds, yes.
i tried to open them with tmpeg enc but it gives me an 'unsupported file' error. -
Rename to mpg.
Author to DVD
Hopefully it's up to DVD specs.
You could try mpegproperties to make sure it is...
/Mats -
You need to author them using something like TMPGenc DVD Author. This will accept m2v files and will create a VIDEO_TS file which you can burn to a DVD-R with something like Nero.
You can also easily add menus etc.
Hope this helps. -
thanks.
actually i just got a call from a friend who told me to try TMPGEnc DVD Source Creator from http://www.pegasys-inc.com (trial version). that's what i did and it works EXCELLENT !!
so, anyone who had the same problem - try this, it's great !
and a big THANK YOU to everyone who responded !!!!
.m2v and .ac3 to DVD - mac - HELP!
By walke803 in forum Authoring (DVD)Replies: 1Last Post: 3rd Oct 2011, 15:44 -
dvd m2v time delay problem
By codemaster in forum DVD RippingReplies: 14Last Post: 28th Nov 2010, 20:02 -
Hidef(.mkv) to DVD(.m2v) with Avisynth.
By RaChe in forum Video ConversionReplies: 4Last Post: 1st Sep 2010, 15:09 -
Take a .VOB or .M2V file + inverse telecine it so output is .VOB or .M2V?
By DrGori in forum Video ConversionReplies: 20Last Post: 10th Oct 2009, 20:25 -
muxing m2v with m2v?
By just in forum Newbie / General discussionsReplies: 4Last Post: 30th Dec 2008, 00:05
