whenever i try to open a .avs file for editing in premiere pro 7.0, i get a scrambled look to the movie. The file can't be edited because i cant view it at all. if i open the movie for editing in 6.0 premiere, i have no problems. Also, keep in mind i have followed every avenue, i.e. changing preview size to 720 x 480 and interpreting footage to square pixels, but still same scrambled pic problem... also if i export the vid its scrambled... i have avisynth, i have the plugin installed... so any ideas how to make this work. I had it working before, but after formatting the hard drive, it has never worked since.... help please... i prefer working in 7.0
The software plugin architecture in Premiere Pro 7.0 could be different, or the method/configuration of frameserving to and from the new Premiere is different. Are all the proper input/output avisynth plugin files (im-avisynth.prm I think) in the "\plugins" directory of Premiere?
Download the avisynth tools again from http://www.avisynth.org and http://www.videotools.net .
See this forum's post.
http://www.debugmode.com/forums/viewthread.php?tid=756 -
Unfortunately, the installer won't work correctly..This is a bloody shame, since it was possible to open a .D2V file in Premiere 6.5, and create motion menus and such, from the original .VOB files...Really impressive stuff. 8)Are all the proper input/output avisynth plugin files (im-avisynth.prm I think)
Does anybody know any other way of opening an .AVS into Premiere Pro??
I haven't a clue... -
No guarantees because I don't have Premiere Pro ,but there is a little program out there called MakeAVIS (Google it!) that , basically ,creates a fake avi from an avs script. It has the option of uncompressing the audio which is the only way I could get it to work. You could always play with it and see if it works.
Exporting from Adobe Premiere Pro not working
By Devilsadvocate in forum EditingReplies: 1Last Post: 29th Mar 2012, 12:04 -
Premiere Pro CS4 trouble working with mp4 clips
By LisaK2277 in forum MacReplies: 2Last Post: 18th May 2011, 10:52 -
Going from premiere 1.5 Pro to CS3 Pro - Working with a new Canon HV-20
By Tumbo in forum Newbie / General discussionsReplies: 26Last Post: 24th Apr 2008, 17:25 -
Working with converting using tmpgence and adobe premiere pro 2.0
By Dante016 in forum Newbie / General discussionsReplies: 4Last Post: 19th Jun 2007, 21:56 -
Adobe Premiere project using AVISynth AVS scripts crashes when rendering!
By Mark001 in forum EditingReplies: 2Last Post: 11th Jun 2007, 00:25
