I followed the guide on making SVCDs from the ffmpegX website and I end up with four files produced per disc.
1)movie.mpg_01.img
2)movie.mpg_02.img
3)movie.mpg_02_pregap.img
4)movie-1.mpg.toc
I tried using toast to burn them _01.img and _02.img files and made two cds that are unreadable using my dvd player and vcd. Which of these files are required and in what order??
Also what codecs do i need to get quicktime to play SVCD mpegs?? Right now i can only view these files with vlc or mplayer.
Thanks for the help
Guest
Toast 6 --> Copy --> Multi-Track CD-ROM XAOriginally Posted by Guest
drop the two image files in the window that pops up after clicking "Select...", burn at slower speeds. If your DVD-Player is able to play SVCDs than this should work. VLC also recognizes SVCDs. QuickTime can only play the mpeg files and not SVCDs. For mpeg2 playback you need the Mpeg2 QuickTime Component.
hth
y.
Guest
When i play the svcd created when i burn the two .img files using Toast with VLC I get the following error:
dvd: fatal failure in ifo
vcd: could not read block 450
vcd: could not read sector 450
ps: cannot peek()
avi: cannot peek()
ts_dvbpsi: cannot peek()
ts: cannot peek()
dtssys: cannot peek()
flac: cannot peek()
id3tag: cannot peek()
id3: cannot peek()
a52sys: cannot peek
id3: cannot peek()
mpga: cannot peek
mpgv: cannot peek
livedotcom: cannot peek
main: no suitable demux module for `/ps:///dev/disk2'
Is this a problem with Toast, VLC or ffmpegX??
Make SVCD from prepared directory
By Gimballon in forum Authoring (VCD/SVCD)Replies: 2Last Post: 18th Jun 2008, 08:35 -
Toast 8 - Can I join 2 avi files to make one video?
By Ivor Bigone in forum MacReplies: 5Last Post: 13th Feb 2008, 10:32 -
How do I make my Samsung R150 recorder region free? I have the code to make
By charpee in forum DVD & Blu-ray RecordersReplies: 2Last Post: 26th Jan 2008, 07:10 -
How to make a VCD/SVCD with CD Audio (CDDA)
By Baldrick in forum User guidesReplies: 74Last Post: 24th Dec 2007, 19:37 -
Toast 8.0.3
By lawnman in forum MacReplies: 1Last Post: 17th Nov 2007, 07:00
